G Cross Country 2024
The GasGas G Cross Country is the brand's entry-level e-hardtail range, sitting below its full-suspension trail and enduro models. It is built around a 6061 alloy frame and a Yamaha mid-drive motor, pitched squarely at newer riders building off-road skills rather than aggressive trail use.
The range splits cleanly. The 1.0 (£1,599) is the small-rider option: 27.5in wheels, a 100mm SR Suntour coil fork, an external 400Wh Yamaha battery and the gentler 50Nm Yamaha PW-CE motor with a basic 8-speed Tektro drivetrain. The 2.0 (£2,699) steps up to 29in wheels, a 120mm coil fork, an integrated 630Wh Simplo battery and the 70Nm PW-ST motor, still on a 9-speed Tektro groupset. The 3.0 (also £2,699) keeps the 29in wheels and 630Wh battery but adds the punchier 85Nm Yamaha PW-X3 motor, an air-sprung RockShox 35 Silver TK fork, SRAM Level T hydraulic brakes and a 12-speed SRAM SX Eagle drivetrain. At the same price, the 3.0 is the stronger value for anyone wanting the most capable build, while the 2.0 trades the better fork and motor for an extra XL size.
Geometry is conservative and confidence-focused rather than aggressive. The 29in 2.0 and 3.0 share a 67 degree head angle, 74 degree seat angle, 475mm chainstays and modest reach figures (440mm M, 450mm L, with the 2.0 adding a 460mm XL). The 27.5in 1.0 is steeper at 69 degrees with shorter 465mm stays and lower stack, reflecting its smaller-rider, beginner brief.
| S | M | L | XL | |
| Reach | 400 mm | 420 mm | 440 mm | 460 mm |
| Stack | 626 mm | 630 mm | 636 mm | 665 mm |
| Seattube | 400 mm | 450 mm | 500 mm | 550 mm |
| Chainstay | 465 mm | 465 mm | 465 mm | 475 mm |
| Headtube Angle | 69° | 69° | 69° | 67° |
| Seattube Angle (eff) | 74° | 74° | 74° | 74° |
| Wheelbase | 1136 mm | 1156 mm | 1176 mm | 1233 mm |
| Headtube | 120 mm | 125 mm | 130 mm | 140 mm |
| BB Height | — | — | — | 319 mm |
| Front Centre | 671 mm* | 691 mm* | 711 mm* | 758 mm* |
Trims · 3
1.0 £1,599 | 2.0 £2,699 | 3.0 £2,699 | |
| Motor | Yamaha PW-CE · 85 Nm | Yamaha PW-ST · 85 Nm | Yamaha PW-X3 · 85 Nm |
| Battery | Simplo 630 · 630 Wh · all trims | ||
| Travel F/R | 120/? mm · all trims | ||
| Frame | Aluminium · all trims | ||
| Fork | SR SUNTOUR XCT30, Coil, 100 mm | SR SUNTOUR XCM32 NLO, Coil, 120 mm, tapered | RockShox 35 Silver TK, Solo Air, Air, 120 mm, tapered |
| Headset | GASGAS ZS44/ZS56 · all trims | ||
| Stem | GASGAS 31,8, 7 °, Ahead · all trims | ||
| Handlebar | GASGAS Riser 31.8 mm, 720 mm, Sweep: 6 °, Rise: 15 mm · all trims | ||
| Grips | GASGAS MTB, Lock-on grips · all trims | ||
| Saddle | GASGAS MTB · all trims | ||
| Seatpost | GASGAS, 31.6 mm, 350 mm, Patent · all trims | ||
| Brakes | Tektro HD-M275, 2-piston, Hydraulic disc brake (front and rear) | Tektro HD-M275, 2-piston, Hydraulic disc brake (front and rear) | SRAM Level T, 2-piston, Hydraulic disc brake (front and rear) |
| Rear derailleur | Tektro RD-T350, 8-S | Tektro RD-T350, 9-S | SRAM SX Eagle, 12-S |
| Crank | GASGAS EC40, Aluminum forged, JIS; Chainring GASGAS, 38 T | GASGAS EC40, Aluminum forged, JIS; Chainring GASGAS, 38 T | GASGAS EC40, Aluminum forged, ISIS; Chainring SRAM X-Sync Eagle, 38 T |
| Shifters | Tektro SL-M330R | Tektro SL-M350R | SRAM SX Eagle, Single Click |
| Cassette | Tektro CS-M330, 11-42 T | Tektro CS-M350, 11-46 T | SRAM PG-1210, 11-50 T |
| Chain | KMC Z8 | KMC e9S | SRAM SX Eagle |
| Drivetrain | Tektro RD-T350, 8-S; GASGAS EC40, Aluminum forged, JIS; Chainring GASGAS, 38 T; Tektro SL-M330R; Tektro CS-M330, 11-42 T; KMC Z8 | Tektro RD-T350, 9-S; GASGAS EC40, Aluminum forged, JIS; Chainring GASGAS, 38 T; Tektro SL-M350R; Tektro CS-M350, 11-46 T; KMC e9S | SRAM SX Eagle, 12-S; GASGAS EC40, Aluminum forged, ISIS; Chainring SRAM X-Sync Eagle, 38 T; SRAM SX Eagle, Single Click; SRAM PG-1210, 11-50 T; SRAM SX Eagle |
| Wheels | Mach 1 TRAXX, With eyelets, Tubeless ready | Mach 1 TRAXX, With eyelets | Mach 1 TRAXX, With eyelets |
| Tyres | Mitas Ocelot, 27.5 x 2.35 | Continental Cross King, 58-622, 29 x 2.3 | Continental Cross King, 58-622, 29 x 2.3 |
| Weight | 21.9 kg | 23.9 kg | 23.2 kg |
| Price | £1,599 | £2,699 | £2,699 |
Rides similarly
Spot a mistake?
