Bike Finder · Canyon
Canyon Neuron:ON
Canyon
Neuron:ON 2024
DiscontinuedTrail eMTBLegacy · 2.5/10iFreshness 2.5/10
Versatile trail eMTB all-rounder
Travel F/R
140/130mm
Wheels
29F/29R
Frame
Full carbon
Weight
22.6 kg
Price
From £4,861
View the Canyon Neuron:ON on Canyon’s site
Canyon Neuron:ON 2024
From £4,861
EMTB Forums verdict
The Canyon Neuron:ON 2024 is the Koblenz direct-to-consumer brand's carbon trail eMTB: a Horst-link 4-bar chassis with 140 mm of travel front and rear, the Bosch Performance Line CX Gen 4 motor at 85 Nm of torque, and an integrated 750 Wh PowerTube battery. At a claimed 22.6 kg, this is a do-it-all trail platform pitched directly at riders who want full Bosch power in a more accessible 140 mm package than the long-travel Spectral:ON or Torque:ON siblings. Production status is gold-listed as discontinued — buyers should check current availability before ordering.
Drive system and range. The Bosch Performance Line CX Gen 4 delivers 85 Nm of torque. The 750 Wh PowerTube battery is gold-listed as removable, though forum data from earlier Neuron:ON variants flags this as a known concern. One rider reports the original released Neuron:ON CF models had non-removable batteries: "didn't realise at first that the battery on the Neuron:ON CF models can't be removed for charging — that's the end of that then." Another rider calls the non-removable battery design a major doubt. Buyers should verify removability on the specific trim and year before ordering. Real-world range on the Bosch CX with 750 Wh typically lands at 1,400–1,800 m of climbing per charge.
Geometry and handling. Head angles vary by size and frame variant — 65.5° to 67.5° per the gold table. This is firmly trail rather than enduro territory. Reach progresses from 405 mm (XS) through 425 mm (SM), 435 mm (S/MD/SM), 455 mm (LG), 460 mm (M/MD) and up to 510 mm on XL options. Chainstays sit at 435–450 mm depending on size and trim. Wheelbase grows 1,135 mm to 1,286 mm. The Neuron:ON has 13 nominal size points, including dual sizing conventions and within-size geometry variants — confusing for buyers but practical for fit. 29-inch wheels on M–XL, 27.5-inch on XS–S. The platform's positioning is the calm, versatile, accessible trail bike — not a slack enduro sled.
Build and value. Three trims share the carbon chassis with broadly equivalent £4,861–£5,349 base spec: RockShox Pike Ultimate fork (140 mm), Deluxe Select R shock, SRAM Code RSC 4-piston brakes (203 mm rotors) and SRAM GX Eagle AXS Transmission wireless 12-speed. At under £5,500 with carbon construction and AXS T-Type, this was strong value when current.
Community-verified strengths. Canyon's broader Neuron lineup has earned positive forum reception. @Rockhopper70 bought a Canyon Neuron:ONfly (Bosch SX-powered sibling) and "after two rides really pleased with it." Canyon's direct-to-consumer pricing remains a meaningful advantage; spec-for-spec their bikes typically undercut dealer-network rivals by 15–25%.
Caveats and known gripes. Production status is the most significant caveat: the Neuron:ON CF was removed from Canyon's website in May 2025, per @drocho. Only the Neuron:ON AL and Neuron:ONfly remain in current production. Buyers should verify availability before committing. @drocho also notes "Canyon's situation in this eMTB category is not that good" — flagging unresolved "battery gate" problems on Spectral:ON and Torque:ON, with owners still waiting for new batteries. A Neuron:ON early buyer reports a battery issue on the AL model that took over 3 weeks with no progress through the service centre. Canyon's direct-to-consumer servicing pathway can be slow during peak issues. The 65.5°+ head angle is steeper than modern trail-enduro alternatives at similar money. The reported non-removable battery on early CF models is a known frustration — verify with Canyon.
Verdict. The Canyon Neuron:ON 2024 was a credible carbon trail eMTB platform with the Bosch Performance Line CX Gen 4 motor at compelling direct-to-consumer pricing, but the gold-listed discontinued status and forum-documented battery-and-service concerns mean buyers should approach with caution. It would have suited buyers who want full Bosch power in a 140 mm trail package, accept Canyon's direct-to-consumer ordering model and don't need a long-travel enduro. With the CF model now unavailable, buyers should look at the surviving Neuron:ON AL (Bosch CX alloy), Neuron:ONfly (Bosch SX lightweight), Canyon Grand Canyon:ON hardtail, or the Cube Stereo Hybrid One77 SLX as a similar Bosch CX full-suspension alternative with proven dealer support. Production status: discontinued.
💬 Forum discussion
Canyon Neuron:On / E8000 problem
22 replies · 7.4k views · last reply 62 months ago
Join the discussion →
Frame
Carbon (CF) frame, Horst-link 4-bar, 140mm rear travel, 29in wheels (M-XL) and 27.5in (XS-S), integrated 750Wh battery (non-removable), Cat 3 testing standard, UDH-compatible.
Bike geometry diagram
XSSMLXL
Reach405 mm425 mm435 mm455 mm475 mm
Stack584 mm607 mm625 mm634 mm644 mm
Chainstay435 mm435 mm440 mm440 mm440 mm
Headtube Angle66.5°66.5°67.5°67.5°67.5°
Seattube Angle (eff)75°75°74.5°74.5°74.5°
BB Drop20 mm20 mm33 mm33 mm33 mm
Wheelbase1135 mm1165 mm1175 mm1199 mm1223 mm
Headtube100 mm100 mm120 mm130 mm140 mm
Standover766 mm772 mm798 mm800 mm808 mm
Front Centre700 mm730 mm735 mm759 mm783 mm
Trims · 2
(base) (colon-strip dupe)
£4,861
CF
£5,349
MotorBosch Performance Line CX · 85 NmBosch Performance Line CX Gen 4 · 85 Nm
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R140/130 mm · all trims
FrameCarbon · all trims
ForkRockShox Pike Ultimate, 140mm travel (CF 9 trim) · all trims
ShockRockShox Deluxe Select R · all trims
HeadsetAcros Block Lock integrated headset · all trims
StemCanyon:ON ST0031 · all trims
HandlebarCanyon:ON HB0056 Riser Bar, 800mm · all trims
GripsCanyon Lock-On · all trims
SaddleFizik Terra Alpaca X5 · all trims
SeatpostIridium Dropper Post · all trims
BrakesSRAM Code RSC, 4-piston, 203mm rotors · all trims
Rear derailleurSRAM GX Eagle AXS Transmission · all trims
CrankSRAM X1, 165mm, single chainringSRAM X1, 165mm
ShiftersSRAM AXS Pod Ultimate · all trims
CassetteSRAM GX Eagle Transmission, 12-speed, 10-52t · all trims
ChainSRAM GX Eagle Transmission Flattop · all trims
Drivetrain1x12 SRAM GX Eagle AXS Transmission · all trims
WheelsDT Swiss HX1700 wheelset, 29in (M-XL) or 27.5in (XS-S) · all trims
TyresSchwalbe Nobby Nic 29x2.4in Addix SpeedgripSchwalbe Nobby Nic 29x2.4in Addix Speedgrip Super Ground
Weight22.6 kg · all trims
Price£4,861£5,349
Rides similarly
Spot a mistake?
