Bike Finder · Canyon
Canyon Neuron:ON
Canyon
Neuron:ON 2023
DiscontinuedFull Power · Cross-CountryLegacy · 0.4/10iFreshness 0.4/10
Motor
Shimano EP8 (DU-EP800) · 85Nm · 500W
Battery
Shimano BT-E8036 · 630Wh
Travel F/R
130/130mm
Wheels
29F / 29R
Frame
Aluminium
Weight
24.6 kg
Price
From £3,649
View the Canyon Neuron:ON on Canyon’s site
Canyon Neuron:ON 2023
From £3,649
EMTB Forums verdict
The 2023 Canyon Neuron:ON (alloy) is the brand's adventure-minded trail eMTB: a full-suspension 29er with 130 mm of travel front and rear (120 mm fork on the smaller XS and S frames) built around a robust aluminium frame and Canyon's Triple Phase Suspension linkage. Unlike the carbon Neuron:ON CF that arrived alongside it, this alloy version is Shimano-powered, not Bosch.
Power comes from Shimano STEPS: the EP8 (DU-EP800, 85 Nm) on the 7, 8 and 9, and the value-focused EP6 (DU-EP600, also 85 Nm) on the entry 6. A 630 Wh Shimano battery features on M to XL frames, dropping to 504 Wh on the shorter XS and S. Four UK trims spanned the range, from the Deore-equipped Neuron:ON 6 at £3,649 up to the Neuron:ON 9 at £5,249 with its RockShox Pike Select+ fork, SRAM Code R brakes and wireless GX Eagle AXS shifting.
Geometry is moderate rather than aggressive, in keeping with its do-it-all trail brief: a 66.5 to 67.5 degree head angle, roughly 74.5 to 75 degree effective seat angle, 435 to 440 mm chainstays and reach growing from 405 mm (XS) to 475 mm (XL). It is a stable, comfortable all-day mileage machine rather than a steep-and-rowdy enduro tool.
This model year is now discontinued. Canyon's later Neuron:ON range consolidated around the carbon, Bosch-powered Neuron:ON CF platform with longer 140 mm travel and updated geometry, leaving this Shimano-equipped alloy generation as the more affordable, touring-leaning chapter of the line.
Geometry read
Size
Descending
52
A solid all-round descender (67.5° head angle, 130mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
62
Size balance
88
Rear-long with a planted front in L (FC:RC 1.73) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
73
Shimano EP8 (DU-EP800) and a steep 74.5° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
How it stacks up vs other Full Power · Cross-Country bikes (from 111 bikes in the database)
Weight24.6 kg1.0 kg heavier than average
Battery630 Wh64 Wh below average
Motor torque85 Nmabout average torque
Value for money44/100from £3,649 · most Shimano EP8 (DU-EP800) bikes ~£3,499
💬 Forum discussion
Canyon Neuron:On / E8000 problem
22 replies · 7.4k views · last reply 62 months ago
Join the discussion →
Bike geometry diagram
XSSMLXL
Reach405 mm425 mm435 mm455 mm475 mm
Stack584 mm607 mm625 mm634 mm644 mm
Seattube380 mm420 mm440 mm480 mm520 mm
Chainstay435 mm435 mm440 mm440 mm440 mm
Headtube Angle66.5°66.5°67.5°67.5°67.5°
Seattube Angle (eff)75°75°74.5°74.5°74.5°
Wheelbase1165 mm1175 mm1199 mm1223 mm
Headtube100 mm100 mm120 mm130 mm140 mm
BB Height335 mm341 mm341 mm341 mm
Standover766 mm772 mm798 mm800 mm808 mm
Front Centre730 mm*735 mm*759 mm*783 mm*
FC:RC1.681.671.731.78
Trims · 4
£3,649
7
£3,849
8
£4,149
9
£5,249
MotorShimano EP6 (DU-EP600) · 85 NmShimano EP8 (DU-EP800) · 85 NmShimano EP8 (DU-EP800) · 85 NmShimano EP8 (DU-EP800) · 85 Nm
BatteryShimano BT-E8036 · 630 Wh · all trims
Travel F/R130/130 mm · all trims
FrameAluminium · all trims
ForkFOX 34 Rhythm GRIP, 130 mm (120 mm in sizes XS-S), 34 mm stanchionsFOX 34 Rhythm, 130 mm (120 mm in sizes XS-S), 34 mm stanchionsFOX 34 Performance Elite 29, 130 mm, GRIP2 cartridgeRockShox Pike Select+, 130 mm, Charger 2.1 damper, DebonAir
ShockFOX FLOAT DPS Performance, 130 mm rear travelFOX FLOAT DPS Performance, 130 mm rear travel; 210x50 mm (M-XL), 190x45 mm (S)FOX FLOAT DPS Performance, 130 mm rear travel; 210x50 mm (M-XL), 190x45 mm (S)RockShox Deluxe Select R, 130 mm rear travel, external rebound
StemCanyon:ON Stem, 35 mm clamp, 60 mm lengthFSA Comet 35, 35 mm clampFSA Comet 35, 35 mm clampFSA Comet 35, 35 mm clamp
HandlebarCanyon:ON HB0056 Riser, alloy, 35 mm clamp, 760 mm width, 20 mm riseFSA Comet Alloy 35 Riser, 760 mm width, 25 mm riseFSA Comet Alloy 35 Riser, 760 mm width, 25 mm riseFSA Comet Alloy 35 Riser, 760 mm width, 25 mm rise
GripsCanyon Lock-On · all trims
SaddleFizik Terra Alpaca X5 · all trims
SeatpostIridium Dropper Post, internal routing, 30.9 mm clamp · all trims
BrakesShimano MT420 4-piston (front) / Shimano BR-MT410 Deore 2-piston (rear), 203 mm rotorsShimano MT420 4-piston (front) / Shimano BR-MT410 Deore 2-piston (rear), 203 mm rotorsShimano XT BR-M8120 4-piston (front) / Shimano XT BR-M8100 (rear), ICE TECH pads, 203 mm rotorsSRAM Code R 4-piston, SRAM Centerline 200 mm rotors
Rear derailleurShimano Deore M6100, 1x12, long cageShimano Deore M6100, 1x12Shimano Deore XT M8100, 1x12SRAM GX Eagle AXS wireless, 1x12
CrankShimano STEPS E-MTBFSA CK 752 E-MTB, 1xShimano STEPS E-MTB, 170 mmShimano STEPS E-MTB, 170 mm
ShiftersShimano Deore M6100 12-speedShimano Deore M6100 12-speedShimano Deore M6100 12-speedSRAM GX Eagle AXS Controller (wireless)
CassetteShimano Deore CS-M6100 12-speed, 10-51TShimano Deore CS-M6100 12-speed, 10-51TShimano Deore CS-M6100 12-speed, 10-51TSRAM GX Eagle XG-1275 12-speed, 10-52T
ChainShimano CN-M6100 12-speedShimano CN-M6100 12-speedShimano CN-M6100 12-speedSRAM GX Eagle 12-speed
DrivetrainShimano Deore M6100, 1x12, long cage; Shimano STEPS E-MTB; Shimano Deore M6100 12-speed; Shimano Deore CS-M6100 12-speed, 10-51T; Shimano CN-M6100 12-speedShimano Deore M6100, 1x12; FSA CK 752 E-MTB, 1x; Shimano Deore M6100 12-speed; Shimano Deore CS-M6100 12-speed, 10-51T; Shimano CN-M6100 12-speedShimano Deore XT M8100, 1x12; Shimano STEPS E-MTB, 170 mm; Shimano Deore M6100 12-speed; Shimano Deore CS-M6100 12-speed, 10-51T; Shimano CN-M6100 12-speedSRAM GX Eagle AXS wireless, 1x12; Shimano STEPS E-MTB, 170 mm; SRAM GX Eagle AXS Controller (wireless); SRAM GX Eagle XG-1275 12-speed, 10-52T; SRAM GX Eagle 12-speed
WheelsRODI TRYP30 EVO, Center Lock, 29inRodi TRYP 30, Shimano MT400/MT410 hubs, 30 mm inner width, BoostRodi TRYP 30, Shimano MT400/MT410 hubs, 30 mm inner width, BoostDT Swiss H 1900 Spline Hybrid 29, 6-bolt
TyresSchwalbe Nobby Nic Performance 29x2.6inSchwalbe Nobby Nic Performance 29x2.6inSchwalbe Nobby Nic SuperTrail Speedgrip 29x2.6in (front) / Schwalbe Hans Dampf SuperTrail 29x2.6in (rear)Schwalbe Nobby Nic SuperTrail Speedgrip 29x2.6in (front) / Schwalbe Hans Dampf SuperTrail 29x2.6in (rear)
Weight24.6 kg
Price£3,649£3,849£4,149£5,249
Rides similarly
Spot a mistake?
