Bike Finder · Cannondale
Cannondale Moterra SL
Cannondale
Moterra SL 2026
CurrentFull Power · TrailAgeing · 3.8/10iFreshness 3.8/10
Shimano EP801 lightweight full-power eMTB (from 19.7kg)
Travel F/R
160/150mm
Wheels
29F/27.5R (mullet, FlipChip for 29F/29R)
Frame
Full carbon
Weight
19.7 kg
Price
From £6,499
View the Cannondale Moterra SL on Cannondale’s site
Cannondale Moterra SL 2026
From £6,499
EMTB Forums verdict
The Cannondale Moterra SL 2026 is the carbon lightweight full-power Moterra, a 19.5 kg trail/enduro chassis built around a custom-tuned Shimano EP801 and a 601 Wh battery. Headline numbers: 160 mm fork, 145 mm rear, 85 Nm of torque, 600 W peak, a properly slack 62.5 degree head angle, reach from 420 to 505 mm, and a £6,499 entry price for the SL 2. The community verdict, summed up by @David Dobson, is that it was "absolutely blown away" by the bike on the Golfie, with the slack front end disappearing under you once you ride it rather than just looking at it.
Drive system and range. The Shimano EP801 is the well-known 2.7 kg, 85 Nm full-power motor with Cannondale's own tune, which softens initial bite for a more natural pedalling feel than out-of-the-box EP8. The 601 Wh integrated pack is small by full-power standards but is the price you pay for the 19.5 kg claimed weight. Real-world range is solid in mild conditions, but @GeordieDownSouth flags a significant winter drop versus a Bosch 625 Wh and frequent BMS resets below 5 degrees, so cold-weather riders should plan accordingly. Owners can also fit Shimano's external battery extender to add capacity for big days.
Geometry and handling. The 62.5 degree head angle is one of the slackest in the lightweight full-power class and sets the Moterra SL apart from rivals at 63.5 to 64.5. Reach progresses 420, 445, 470 and 505 mm with size-specific chainstays (449/449/453/458 mm) and a wheelbase that scales 1219 to 1327 mm, so XL riders get proper rear-centre length. @Rhitter notes the bike feels slightly smaller than comparable sizes (a Large feels smaller than a Large Jekyll), so size up if you are between sizes. The result is a confident, planted descender that still corners playfully thanks to a relatively short rear.
Build and value. Two named trims plus the base frameset sit in the lineup. SL 2 at £6,499 is the volume model and the value sweet spot. SL 1 at £7,999 steps up suspension and finishing kit. @hajpr's Tiger Shark SL2 build shows the platform's upgrade potential: RockShox ZEB Ultimate 3.1 160 mm fork, DT Swiss wheels, Kryptotal DH rubber and a sub-20 kg total weight with an 835 Wh aftermarket pack. Standout choice is the Cannondale-tune EP801 and 62.5 degree front in a 19.5 kg package. Questionable point is the 601 Wh battery and Shimano's locked-down display ecosystem, which @BouncyCornetto caught out trying to fit a Shimano centerlock magnet that the EP801 refused to recognise.
Community-verified strengths. First, that 62.5 degree front end is rated as composed without being slow. @David Dobson says the head angle is "noticeable in a visual way only and not at all" while riding. Second, the chassis disappears under you: @SantaFeKG reckons even the Amflow PL feels like a non-eMTB compared with the Moterra SL's natural ride feel. Third, the platform is highly tunable, with @hajpr documenting display deletion via direct switch wiring and easy ZEB/38 fork swaps.
Caveats and known gripes. Reliability is the headline flag. @Boxmonkey reports an E914 error at around 300 miles causing a complete shutdown, with three Moterra SL owners at the same dealer hitting it: one needed connector cleaning, one a new battery, one a new motor. @GeordieDownSouth separately hit a full EP801 firmware corruption after rough terrain, traced to a loose display cable. The Shimano ecosystem also lacks the OTA polish of Bosch Flow or DJI Avinox.
Verdict. The Moterra SL 2026 is in current production and aimed squarely at trail and enduro riders who want a slack, lightweight full-power carbon with strong dealer support. Buy it if you want a 62.5 degree front, 19.5 kg weight and the EP801 motor in a chassis that swallows aggressive geometry. Look elsewhere if you ride hard winters or need a 700 Wh-plus battery without external add-ons.
💬 Forum discussion
Cannondale Moterra 1,2,3 and SE
127 replies · 56.9k views · last reply 3 months ago
Join the discussion →
“Moterra 3 with a bit of bling. Fully sic bike ?? I bought the base model because they all share the same frame, considerably cheaper, I prefer a lighter 500whr battery, and I had the Fox 36’s from my previous emtb. Absolutely love it,…”
— Davemtb · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Toptube565 mm592 mm619 mm656 mm
Reach420 mm445 mm470 mm505 mm
Stack630 mm639 mm648 mm657 mm
Seattube380 mm400 mm445 mm490 mm
Chainstay449 mm449 mm453 mm458 mm
Headtube Angle62.5°62.5°62.5°62.5°
Seattube Angle (eff)77°77°77°77°
BB Drop30 mm30 mm30 mm30 mm
Wheelbase1219 mm1248 mm1283 mm1327 mm
Headtube115 mm125 mm135 mm145 mm
BB Height335 mm335 mm335 mm335 mm
Standover738 mm737 mm737 mm742 mm
Front Centre770 mm799 mm830 mm869 mm
FC:RC1.711.781.831.90
Trims · 2
£6,499
£7,999
MotorShimano EP801 · 85 Nm · all trims
Battery601 Wh · all trims
Travel F/R160/150 mm · all trims
FrameFull carbon · all trims
ForkFox Performance 36, 160mm travel, Grip Damper, 3-position adjust, 15x110mm Kabolt thru-axle, tapered steerer, 44mm offsetFox Float Factory 36, 160mm travel, Grip X2 Damper, Kashima coating, 15x110mm Kabolt thru-axle, tapered steerer, 44mm offset
ShockFox Float X Performance Elite, 2 pos adj, EVOL LV, 210x55mmFox Float X Factory, 2 pos adj, EVOL LV, 210x55mm
HeadsetAcros Adjustable Angle (1.2°) · all trims
StemCannondale 1, 7075 Alloy, 1-1/8", 35mm, 0° · all trims
HandlebarCannondale 3 Riser, 6061 Alloy, 25mm rise, 8° sweep, 5° rise, 800mmHollowGram SAVE riser bar, Carbon, 35mm clamp, 30mm rise, 8° sweep, 5° rise, 780mm
GripsCannondale TaperRidge · all trims
SaddleFizik Terra Ridon X5, Mobius S alloy railFizik Terra Ridon X3, Mobius Kium alloy rail
SeatpostCannondale DownLow Dropper, internal routing, 31.6, 150mm (S), 170mm (M-L), 200mm (XL)OneUp V3, internal routing, 31.6, 180mm (S), 210mm (M/L), 240mm (XL)
BrakesMagura MT5 4-piston hydraulic disc, 203/203mm Storm HC 6-bolt rotorsMagura MT7 4-piston hydraulic disc, 203/203mm Storm HC 6-bolt rotors
Rear derailleurShimano XTSRAM XO Eagle AXS, T-Type
Cranke*thirteen e*spec Plus, 160mm (S/M), 165mm (L/XL), 34T · all trims
ShiftersShimano XT, 12-speedSRAM AXS POD Controller
CassetteShimano XT, 10-51, 12-speedSRAM XO Eagle, 10-52, T-Type, 12-speed
ChainShimano XT, 12-speedSRAM XO Eagle, T-Type, 12-speed
DrivetrainShimano XT 12-speedSRAM XO Eagle AXS, T-Type, 12-speed
WheelsWTB KOM Trail i30 rims (30mm inner width, TCS tubeless ready); Formula DC-7 front hub, DT Swiss 370 Hybrid LN rear hub; Mullet 29"/27.5"Reserve 30 HD AL rims (30mm inner width, 28h, tubeless ready); DT Swiss 350 front hub, DT Swiss 350 Ratchet System 36 SL rear hub; Mullet 29"/27.5"
Tyres(F) Maxxis DHF, 29x2.5", 3C, EXO+, tubeless ready / (R) Maxxis Dissector, 27.5x2.4", 3C, EXO+, tubeless ready · all trims
Weight19.7 kg
Price£6,499£7,999
Rides similarly
Spot a mistake?
