Slack 62.5° head angle, 150mm travel and a long 1280mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Moterra SL 2024
The 2024 Cannondale Moterra SL was the brand's lightweight full-power eMTB, pitched as the lightest full-power trail bike of its time at a claimed 19.7kg. A carbon FlexPivot four-bar frame gives 150mm rear travel paired with a 160mm fork, driven by a Cannondale-tuned Shimano EP801 motor (85Nm, 600W+ peak) and a custom 601Wh internal battery. The platform is defined by a slack 62.5 degree head angle, a 77 degree effective seat angle and size-specific chainstays (449 to 458mm), with an Acros adjustable-angle headset (1.2 degree range) and a flip chip that switches between the stock MX setup and full 29in wheels.
Three builds were offered. The Moterra SL 1 (around 8,460 GBP) ran Fox Factory 36 and Float X suspension, SRAM XO Eagle AXS T-Type wireless shifting, Code Silver Stealth brakes and DT Swiss XM 1700 alloy wheels. The cheaper SL 2 (around 6,550 GBP) shared the chassis and motor at a lower price point, dropping to a Fox Performance 36 fork and Shimano XT/Deore 12-speed shifting. The halo LAB71 (around 14,000 USD) upgraded to a Series 1 carbon frame, SRAM XX Eagle AXS, Code Ultimate brakes, DT Swiss XMC 1501 carbon wheels, a RockShox Reverb AXS post and OneUp carbon cockpit.
Geometry is firmly modern-trail to light-enduro: long, slack and steep-seated, with the per-size suspension and chainstay tuning Cannondale calls Proportional Response. The adjustable headset and wheel-size flip chip let riders bias the bike toward stability or agility.
The Moterra SL is discontinued as a 2024 model year and no longer appears in Cannondale's range. Buyers should expect clearance or used availability only.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Balanced front-to-rear in L (FC:RC 1.83) — weight sits evenly between the wheels.
Climbs well — a 77° seat keeps the front planted, with 85Nm on tap.
Rewards commitment; it should feel calmer as the speed rises.
How it stacks up vs other Full Power · Trail bikes (from 218 bikes in the database)
| S | M | L | XL | |
| Reach | 420 mm | 445 mm | 470 mm | 505 mm |
| Stack | 630 mm | 639 mm | 648 mm | 657 mm |
| Seattube | 380 mm | 400 mm | 445 mm | 490 mm |
| Chainstay | 449 mm | 449 mm | 453 mm | 458 mm |
| Headtube Angle | 62.5° | 62.5° | 62.5° | 62.5° |
| Seattube Angle (eff) | 77° | 77° | 77° | 77° |
| Wheelbase | 1210 mm | 1240 mm | 1280 mm | 1320 mm |
| Headtube | 115 mm | 125 mm | 135 mm | 145 mm |
| BB Height | 335 mm | 335 mm | 335 mm | 335 mm |
| Standover | 738 mm | 737 mm | 737 mm | 742 mm |
| Front Centre | 761 mm* | 791 mm* | 827 mm* | 862 mm* |
| FC:RC | 1.69 | 1.76 | 1.83 | 1.88 |
Trims · 3
2 £6,549 | 1 £8,459 | LAB71 | |
| Motor | Shimano EP801 · 85 Nm · all trims | ||
| Battery | Cannondale Custom 601Wh · 601 Wh · all trims | ||
| Travel F/R | 160/150 mm · all trims | ||
| Frame | Carbon (Moterra SL Carbon) | Carbon (Moterra SL Carbon) | Carbon (LAB71 Moterra SL, Series 1 Carbon construction) |
| Fork | Fox Performance 36, 160mm | Fox Float Factory 36, 160mm travel, Grip2 Damper, Kashima coating, 15x110mm Kabolt thru-axle, tapered steerer, 44mm offset | Fox Float Factory 36, 160mm travel, Grip2 Damper, Kashima coating, 15x110mm Kabolt thru-axle, tapered steerer, 44mm offset |
| Shock | — | Fox Float X Factory, 2 pos adj, EVOL LV, 210x55mm | Fox Float X Factory, 2 pos adj, EVOL LV, 210x55mm |
| Headset | — | Acros Adjustable Angle (1.2 degree) | Acros Adjustable Angle (1.2 degree) |
| Stem | — | Cannondale 1, 7075 Alloy, 1-1/8", 35mm, 0 degree | OneUp Stem, 6061 Alloy, 1-1/8", 35mm, 0 degree |
| Handlebar | — | HollowGram SAVE riser bar, Carbon, 35mm clamp, 30mm rise, 8 degree sweep, 5 degree rise, 780mm | OneUp Carbon Ebar, 35mm clamp, 35mm rise, 8 degree sweep, 5 degree rise, 780mm |
| Grips | — | Cannondale TaperRidge | Cannondale TaperRidge |
| Saddle | — | Fizik Terra Ridon X3, 145mm, Wingflex, K:ium Mobius rail 7x7mm | Fizik Terra Ridon X1, 145mm, Wingflex, Carbon Mobius rail 7x10mm |
| Seatpost | — | Cannondale DownLow Dropper, internal routing, 31.6, 150mm (S), 170mm (M-XL) | RockShox Reverb AXS, 31.6, 150mm (S), 170mm (M-XL) |
| Brakes | — | SRAM Code Silver Stealth, 4-piston hydraulic disc, 200mm HS2 rotors | SRAM Code Ultimate Stealth, 200mm HS2 rotors |
| Rear derailleur | Shimano XT/Deore, 12-speed | SRAM XO Eagle AXS, T-Type | SRAM XX Eagle AXS, T-Type |
| Crank | — | e*thirteen e*spec Plus, 165mm, 34T | e*thirteen e*spec Race Carbon - Gen 4, 165mm, 34T |
| Shifters | — | SRAM AXS T-Type POD Controller | SRAM Eagle AXS T-Type Ultimate Pod Controller |
| Cassette | — | SRAM XO Eagle, 10-52, T-Type, 12-speed | SRAM XX Eagle, T-Type, 10-52, 12-speed |
| Chain | — | SRAM XO Eagle, T-Type, Flattop | SRAM XX Eagle, T-Type, Flattop |
| Drivetrain | Shimano XT/Deore, 12-speed | SRAM XO Eagle AXS, T-Type; e*thirteen e*spec Plus, 165mm, 34T; SRAM AXS T-Type POD Controller; SRAM XO Eagle, 10-52, T-Type, 12-speed; SRAM XO Eagle, T-Type, Flattop | SRAM XX Eagle AXS, T-Type; e*thirteen e*spec Race Carbon - Gen 4, 165mm, 34T; SRAM Eagle AXS T-Type Ultimate Pod Controller; SRAM XX Eagle, T-Type, 10-52, 12-speed; SRAM XX Eagle, T-Type, Flattop |
| Wheels | — | DT Swiss XM 1700 Spline, 30mm inner width, TC tubeless ready | DT Swiss XMC 1501, carbon, 30mm inner width, hookless, TSS tubeless ready |
| Tyres | — | (F) Maxxis DHF, 29x2.5", 3C, EXO+, tubeless ready / (R) Maxxis Dissector, 27.5x2.4", 3C, EXO+, tubeless ready | (F) Maxxis DHF, 29x2.5", 3C, EXO+, tubeless ready / (R) Maxxis Dissector, 27.5x2.4", 3C, EXO+, tubeless ready |
| Price | £6,549 | £8,459 | — |
Rides similarly
Spot a mistake?
