Bike Finder · Cannondale
Cannondale Moterra Neo
Cannondale
Moterra Neo 2023
DiscontinuedFull Power · TrailLegacy · 1/10iFreshness 1/10
Travel F/R
150/150mm
Wheels
29F / 29R
Frame
Carbon front, aluminium rear / Aluminium
Weight
Price
From £5,750
View the Cannondale Moterra Neo on Cannondale’s site
Cannondale Moterra Neo 2023
From £5,750
EMTB Forums verdict
For 2023 Cannondale comprehensively redesigned the Moterra Neo, dropping it onto a new 150/150mm platform (down from the previous 160mm) and pairing it with Bosch's latest Smart System. It sits as the do-it-all trail member of the Moterra family, with the longer-travel 170/165mm Moterra Neo LT taking over enduro duties. Full 29in wheels are fitted across the range, with a 27.5in rear on size S.
Every trim runs the Bosch Performance Line CX motor (85Nm, up to 340 percent assist) fed by Bosch's largest 750Wh PowerTube, which is removable from the downtube for off-bike charging and managed via a Kiox 300 display. Cannondale's Proportional Response suspension gives each frame size its own kinematics. Three trims were sold: the carbon-front Carbon 1 (Shimano XTR/XT with XT brakes) and Carbon 2 (XT mech, SLX shifting, Shimano MT520 brakes), plus the full-alloy Neo 3 (XT mech, Deore shifting, RockShox Yari fork).
The geometry is moderate and accessible rather than aggressive, with a 65 degree head angle, a steep 77 degree effective seat angle and a tall 350mm bottom bracket, giving a stable, climbing-friendly and beginner-confident character. Long chainstays (452 to 455mm) add to the planted feel at the expense of some playfulness.
The 2023 Moterra Neo has since been discontinued and superseded by Cannondale's latest Moterra range, which moved to the Bosch Performance Line CX Gen 5 (Smart System) motor. As a used buy it remains a versatile big-battery trail eMTB with a proven Bosch drivetrain and a forgiving ride.
Geometry read
Size
Wheels
Descending
61
A solid all-round descender (65° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
32
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
97
Rear-long with a planted front in L (FC:RC 1.79) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
79
Bosch Performance Line CX Gen 4 and a steep 77° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Trail bikes (from 248 bikes in the database)
Battery750 Whabout average capacity
Motor torque85 Nm13 Nm below average
Value for money24/100from £5,750 · most Bosch Performance Line CX Gen 4 bikes ~£4,899
💬 Forum discussion
Cannondale Moterra 1,2,3 and SE
127 replies · 57.5k views · last reply 3 months ago
Join the discussion →
“Moterra 3 with a bit of bling. Fully sic bike ?? I bought the base model because they all share the same frame, considerably cheaper, I prefer a lighter 500whr battery, and I had the Fox 36’s from my previous emtb. Absolutely love it,…”
— Davemtb · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach435 mm455 mm485 mm520 mm
Stack617 mm626 mm635 mm644 mm
Seattube400 mm430 mm460 mm490 mm
Chainstay452 mm455 mm455 mm455 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)77°77°77°77°
Wheelbase1209 mm1235 mm1270 mm1309 mm
Headtube105 mm115 mm125 mm135 mm
BB Height350 mm350 mm350 mm350 mm
Standover755 mm755 mm760 mm770 mm
Front Centre757 mm*780 mm*815 mm*854 mm*
FC:RC1.671.711.791.88
Trims · 3
Neo 3
£5,750
Carbon 2
£7,000
Carbon 1
£8,250
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R150/150 mm · all trims
FrameMoterra Neo SmartForm C1 alloyMoterra Neo Carbon front triangle, SmartForm C1 alloy swingarmMoterra Neo Carbon front triangle, SmartForm C1 alloy swingarm
ForkRockShox Yari RC, 150mm, 15x110mm Boost, 44mm offsetRockShox Lyrik Select, 150mm, DebonAir, 15x110mm thru-axle, tapered steered, 44mm offsetRockShox Lyrik Select+, 150mm, DebonAir, 15x110mm thru-axle, tapered steered, 44mm offset
ShockRockShox Deluxe Select, DebonAir, 2-Pos mode adjust, adjustable rebound, 150mm travel · all trims
HeadsetIntegrated sealed bearing, 1-1/8in - 1.5in taperedAcros integrated sealed bearing, taperedAcros integrated sealed bearing, tapered
StemCannondale 3, 6061 alloy, 31.8, 0 degreeCannondale 2, 6061 alloy, 35mm, 0 degreeCannondale 2, 6061 alloy, 35mm, 0 degree
HandlebarCannondale 3 Riser, 6061 alloy, 15mm rise, 8 degree sweep, 780mmCannondale 3 Riser, 6061 alloy, 25mm rise, 8 degree sweep, 800mmHollowGram SAVE riser bar, carbon, 35mm clamp, 30mm rise, 8 degree sweep, 780mm
GripsFabric FunGuy · all trims
SaddleFabric Scoop Shallow Sport, steel railsFabric Scoop Shallow Sport, steel railsFabric Scoop Shallow Elite, cro-mo rails
SeatpostTranzX dropper, internal routing, 31.6, 130mm (S) / 150mm (M-XL)Cannondale DownLow Dropper, internal routing, 31.6, 125mm (S) / 150mm (M) / 170mm (L-XL)Cannondale DownLow Dropper, internal routing, 31.6, 125mm (S) / 150mm (M) / 170mm (L-XL)
BrakesShimano MT420 4-piston hydraulic disc, 203/203mm rotors, Shimano MT401 leversShimano MT520 4-piston hydraulic disc, 203/203mm RT64 rotors, Shimano MT501 leversShimano XT 8120 4-piston hydraulic disc, 203/203mm RT76 rotors, Shimano XT levers
Rear derailleurShimano XTShimano XTShimano XTR
CrankFSA Bosch E-bike w/ 55mm chainline, 160mm, 34T · all trims
ShiftersShimano Deore M6100, 12-speedShimano SLX, 12-speedShimano XT, 12-speed
CassetteShimano Deore M6100, 10-51, 12-speedShimano SLX, 10-51, 12-speedShimano XT, 10-51, 12-speed
ChainShimano Deore M6100, 12-speedShimano SLX, 12-speedShimano XT, 12-speed
DrivetrainShimano XT; FSA Bosch E-bike w/ 55mm chainline, 160mm, 34T; Shimano Deore M6100, 12-speed; Shimano Deore M6100, 10-51, 12-speed; Shimano Deore M6100, 12-speedShimano XT; FSA Bosch E-bike w/ 55mm chainline, 160mm, 34T; Shimano SLX, 12-speed; Shimano SLX, 10-51, 12-speed; Shimano SLX, 12-speedShimano XTR; FSA Bosch E-bike w/ 55mm chainline, 160mm, 34T; Shimano XT, 12-speed; Shimano XT, 10-51, 12-speed; Shimano XT, 12-speed
WheelsWTB ST i30 TCS, 32h, tubeless readyWTB ST i30 TCS, 32h, tubeless readyWTB KOM Trail i30 TCS, 32h, tubeless ready
Tyres(F) Maxxis Minion DHF 29x2.6" EXO TR, (R) Maxxis Rekon 29x2.6" (27.5x2.6" size S) EXO TR · all trims
Price£5,750£7,000£8,250
Rides similarly
Spot a mistake?
