So, I have a wild fs Mteam that came with the 625wh battery, which most of the time is gives plenty of range, but occasionally on those really big days isn't quite enough.
I know you can get the range extender kit, but that just seems complex(and a bit ugly). I also do some quite short rides after work where I come nowhere near to using a full 625wh.
So I though I'd get a power tube 500wh battery for day to day use, and then on those really big days I can carry the other 625wh battery in the backpack and swap over.
The 500wh battery is about 800g lighter than the 625wh, but is also shorter than the 625wh. So you can either move the mounts which requires tools and is not really something you want to do trailside, or you can buy a spacer to fit to the 500wh battery to make it the same size as the 625wh, so that it just slots into the space.
Anyway so now I have enough battery capacity for enormous days and on those smaller days I have a lighter bike.
