Wheel size in mm
Theolegit
Halstead
Hi does anyone know what wheel size I should enter into my garmin for the levo?
The auto detect function returns useless data and I alway thought it was 2250mm however that gives a reading of 22.5 miles on a 17 mile ride! Any suggestions.
The simplest method is to roll your wheel starting with the valve at the 6 o'clock position make a mark on the floor. Roll the wheel until the valve is once again at the 6 o'clock position and measure the distance between the two.
What wheel sensor do you have for your Garmin. The stand alone rubber strap style sensor that fits to the hub re-calibrates itself when you ride it so I don't think it's massively important how accurate the wheel size you put in is.
The older style combined sensor it is.
as above. But I'd mark the tyre with a pen.
Thanks all, the speed/cadence sensor is built in on the Specialized turbo.
    670K
