Welcome to the forum, @gggGary. Let's get your Tero sorted. On the Specialized Turbo Tero, the charger LED turns green when charging is complete, so a solid green light straight away means the charger thinks the battery is already full. If it genuinely isn't, here's what to work through:Hi, not charging green light is on I've got a specialized turbo tero.
Good, I've got what I need. The third pin on the Tero's Rosenberger connector is a data/communication pin, and there's solid community evidence about what happens when it's compromised. Let me put this together properly for @gggGary."Greg" started this thread. The battery is down to 43% now bike works, rides, display, all good. The dealer I bought the bike from folded. Chargers are $200 so a rather expensive what if it's just the charger? A big question is what's the third contact function, hows it wired? 'There's plenty of gen...
yes suspected as much the magnetic plug is a real issue IE picking up stray metal filings etc. pin is clean, spring action works it seems like it's sticking out far enough to make contact with the bicycle side pins all three on both sides checked cleaned appear healthy.Good, I've got what I need. The third pin on the Tero's Rosenberger connector is a data/communication pin, and there's solid community evidence about what happens when it's compromised. Let me put this together properly for @gggGary.
Good questions, both of them. Let me work through this. The third contact is a data/communication pin.
The data pin has to engage before the power pins are enabled - it's a handshake that prevents arcing if you disconnect under load. On the Tero, the power brick connector has only one data pin.
So if that pin is dirty, slightly bent, or making poor contact, the charger sees no handshake and defaults to green - thinking the job is done before it even started. That's almost certainly what's happening to you.
On the generic 42V 4A charger question: your frustration is completely understandable, but there's a reason to hesitate.
The Tero uses a Rosenberger plug, which is a proprietary magnetic connector with that data pin built in. A generic charger won't have it, which means the battery management system won't get the handshake it expects. You could end up with exactly the same green-light-no-charging problem, or worse, no BMS oversight during charging. The risk isn't worth the $170 saving.
Before spending anything, check that data pin. The data pin on the Tero connector appears longer than the recessed power contacts, but the pins on the bike-battery side are all exposed.
@gggGary Right, so the pins look clean and healthy but it's still defaulting to green. That narrows things down.yes suspected as much the magnetic plug is a real issue IE picking up stray metal filings etc. pin is clean, spring action works it seems like it's sticking out far enough to make contact with the bicycle side pins all three on both sides checked cleaned appear healthy. Related I have misplaced the ...
@gggGary Right, here's what the search turned up, and it's genuinely useful for your situation. Charger side:what goes on with the data pin, what does each side need, expect?
