The bike is a 2022 model but I bought it new a year ago and have hardly ridden it. The only thing that I notice is the cap that covers the charging socket broke off putting the bike on the bike rack and the socket looks as though the copper is slightly green. I have ridden it on a beach just gave it...
Right,
@tomwenlock, that's a very helpful set of clues and I think we can start joining some dots here.
The green patina on your charging socket is copper oxidation, which is basically corrosion from moisture exposure. With the protective cap broken off, that socket has been open to the elements, and if you've ridden it on a beach (salt air, possibly salt spray) and then hit it with a pressure washer, that's more or less the perfect recipe for corroding any exposed copper contacts. Salt accelerates oxidation dramatically, and pressure washers are notorious for forcing water into places it was never meant to go on eBikes, particularly into unsealed connectors and ports.
The charging port corrosion may well be your culprit. Even if the main battery shows full charge, corroded contacts in the charging harness can cause communication faults between the battery, BMS, and TCU that prevent the bike from powering on. This is a known pattern across several eBike platforms. On the Levo specifically, community members have found that grit and debris at the charging port can cause "no battery" errors even when everything is physically connected. Your situation is worse because you've got actual corrosion rather than just dirt. Clean those charging port contacts carefully with electrical contact cleaner (something like DeoxIT or even isopropyl alcohol on a cotton bud) and see if you can get the green off. While you're at it, pop the downtube hatch and inspect the Rosenberger connector I mentioned earlier, because if water got into the charging port, there's a decent chance it's tracked further into the wiring.
Going forward, two things: first, never pressure wash an eBike. A gentle hose, bucket and brush, or a low-pressure rinse is fine, but a pressure washer will find every seal weakness on the bike. Second, get that charging port cap replaced. Your Specialized dealer should be able to order one, and in the meantime even a small piece of electrical tape over the port when not charging will keep moisture out. Dielectric grease on the male connector (just a thin film, not packed into the socket itself) will also help protect against future corrosion.
If cleaning the contacts doesn't bring it back to life, a dealer visit is likely on the cards to check whether the corrosion has reached the BMS or TCU wiring. Given the bike's still relatively young and you bought it new, check whether your Specialized warranty covers this, though the pressure washing and missing cap might complicate that conversation.
