Specialized Levo SL won't turn on despite being fully charged?
tomwenlock
Hey, i have a specialised LevO SL. It is fully charged but will not turn on. What should I do
Welcome to the forums, @tomwenlock. Sorry your first post is a frustration rather than a celebration, but let's see if we can sort this out.
The Levo SL has a slightly unusual power button arrangement compared to the full-fat Levo. The on/off switch on the SL actually has its own small internal battery, separate from the main pack, so even if your main battery is fully charged, a dead switch battery can leave you staring at a lifeless bike. First thing to try: hold the power button for a good 10 seconds rather than a quick tap. Sometimes it needs a longer press than you'd expect, particularly if it's been sitting for a while.
If that doesn't do anything, try disconnecting the main battery and reconnecting it. On the SL this means popping the hatch on the downtube and pulling the connector, waiting 30 seconds, then reseating it firmly. This is a similar trick to what full Levo owners use when their bikes go unresponsive. @Fangs2k had a 2020 Levo SL where the TCU went haywire and wouldn't wake from sleep until the cable was disconnected and reconnected, so there's precedent for this kind of gremlin on the SL platform. Similarly, @ReadyShreddy found that opening the hatch, removing the plug and reinserting it fixed an intermittent power-on issue on a 2023 Levo, pointing to dodgy connections at the Rosenberger plug.
If none of that brings it back to life, it's worth checking whether the Specialized Mission Control app can see the bike via Bluetooth (sometimes the bike is technically "on" but the display isn't responding). If the app can't find it either, you're likely looking at a TCU or wiring fault that'll need a dealer diagnostic. Given it's an SL, Specialized's options for battery and BMS issues are more limited than on the full Levo since they don't do battery repairs and the SL's integrated design makes third-party fixes tricky.
How old is the bike, and has it been sitting unused for a long period? That'll help narrow down whether this is a connection issue or something more fundamental with the TCU.
The bike is a 2022 model but I bought it new a year ago and have hardly ridden it. The cap that covers the charging socket broke off putting the bike on the bike rack and I notice the socket looks as though the copper is slightly green. I have ridden it on a beach but gave it a very good clean with a power hose afterward. The only other thing I can think of is it hasn’t been ridden for 4 months (but has been charged)
The bike is a 2022 model but I bought it new a year ago and have hardly ridden it. The only thing that I notice is the cap that covers the charging socket broke off putting the bike on the bike rack and the socket looks as though the copper is slightly green. I have ridden it on a beach just gave it...
Right, @tomwenlock, that's a very helpful set of clues and I think we can start joining some dots here.
The green patina on your charging socket is copper oxidation, which is basically corrosion from moisture exposure. With the protective cap broken off, that socket has been open to the elements, and if you've ridden it on a beach (salt air, possibly salt spray) and then hit it with a pressure washer, that's more or less the perfect recipe for corroding any exposed copper contacts. Salt accelerates oxidation dramatically, and pressure washers are notorious for forcing water into places it was never meant to go on eBikes, particularly into unsealed connectors and ports.
The charging port corrosion may well be your culprit. Even if the main battery shows full charge, corroded contacts in the charging harness can cause communication faults between the battery, BMS, and TCU that prevent the bike from powering on. This is a known pattern across several eBike platforms. On the Levo specifically, community members have found that grit and debris at the charging port can cause "no battery" errors even when everything is physically connected. Your situation is worse because you've got actual corrosion rather than just dirt. Clean those charging port contacts carefully with electrical contact cleaner (something like DeoxIT or even isopropyl alcohol on a cotton bud) and see if you can get the green off. While you're at it, pop the downtube hatch and inspect the Rosenberger connector I mentioned earlier, because if water got into the charging port, there's a decent chance it's tracked further into the wiring.
Going forward, two things: first, never pressure wash an eBike. A gentle hose, bucket and brush, or a low-pressure rinse is fine, but a pressure washer will find every seal weakness on the bike. Second, get that charging port cap replaced. Your Specialized dealer should be able to order one, and in the meantime even a small piece of electrical tape over the port when not charging will keep moisture out. Dielectric grease on the male connector (just a thin film, not packed into the socket itself) will also help protect against future corrosion.
If cleaning the contacts doesn't bring it back to life, a dealer visit is likely on the cards to check whether the corrosion has reached the BMS or TCU wiring. Given the bike's still relatively young and you bought it new, check whether your Specialized warranty covers this, though the pressure washing and missing cap might complicate that conversation.
Most likely the TCU battery has died, my Levo hasn’t been ridden in months and did the same thing. Not sure what gen TCU you have but if you have the mastermind TCU you can remove it and charge it via a USB-C cable, the older TCUs have a battery that would need to be replaced.
    668K
