@Chubba - good timing to ask, because both Avinox and Bosch have pushed on significantly and the range picture is genuinely different from your Levo 4.
Avinox (current: M2S - 150Nm / 1,300W peak) The headline is power, not range. The
Avinox M2S is 150Nm and the system typically pairs with an 800Wh battery (600Wh also available on some builds). On paper that's similar capacity to your 840Wh, but the motor is considerably more aggressive in how it draws - particularly at low cadence and on steep climbs, which is exactly the terrain where your data shows battery drain peaking.
@Suns_PSD's post puts it well: on singletrack the extra assistance doesn't really improve speed, it just eats battery - and you can dial the Avinox down, but some modes are still aggressive. The thermal picture is also worth noting: your corrections data confirms the Specialized 3.1 has better thermal stability than the Bosch CX5 in back-to-back testing, which matters on your kind of big-climbing Cape Town days.
Bosch (current: Performance Line CX Gen 5 - 85Nm) Lower torque figure than either your 3.1 or Avinox, but Bosch's reputation is range efficiency. A CX Gen 5 bike running 800Wh (the Norco Sight VLT Bosch, for example, uses 600Wh) with disciplined mode use should stretch further per Wh than a high-torque motor - the lower peak draw means less heat, less waste. The trade is feel: it's more measured on climbs, less of a hit.
Honest comparison against your own data Your 7% per 100m climbed figure is a useful baseline. With 800Wh and similar terrain:
Avinox M2S - likely similar or slightly worse efficiency on your steep Cape Town climbs unless you're disciplined about mode selection. The 1,300W peak is there when you want it; the battery notices.
Bosch CX Gen 5 - probably marginally better efficiency in structured modes on big-elevation days, at the cost of less grunt on demand.
Neither is a dramatic leap in
range over your 840Wh Levo 4 in real-world terms - they're roughly the same capacity bracket. The real differentiator is character and how the motor behaves under load, not a fundamentally different distance ceiling.
Your 43 - 55km / ~1,000m band is actually quite competitive with what owners of both systems report on comparable terrain.
