Shimano Steps EW-SW310 switch dead — back pedalling jump starts but instantly dies?
Quick clarification first: the EW-SW310 isn't your motor — it's the wiring junction/sub-harness in the STEPS system. So what you're describing is a power/comms fault somewhere in that loop, not a motor failure as such. That's actually good news, because harness and switch faults are usually cheaper to chase than a dead drive unit.
Here's what your symptom is telling us. Back-pedalling spins the motor's generator enough to briefly wake the system, but the moment you stop, it dies — which means the bike isn't getting a stable power feed from the battery through to the controls. Classic culprits, roughly in order of likelihood:
1. Dead or flat switch/display, or its feed
On STEPS, if the switch unit has no power, the whole bike won't boot. @philippe1 has flagged the back-pedal jump-start trick before — spinning the cranks backwards firmly can force a start — but if it instantly dies, the switch isn't holding the system awake. Worth checking the switch is actually powering up at all.
2. Battery-to-harness connection
A poor seat between the battery and the main harness is the most common cause of exactly this "no power / intermittent" behaviour. @Stihldog found a bad battery-to-harness connection threw intermittent power loss and error codes; @digitale traced a similar mid-ride shutoff on a Spectral:ON to a power cable that needed reseating onto the motor. Pull the battery, check the contacts for corrosion or a bent pin, reseat it firmly.
3. The SW310 sub-harness / connectors themselves
Canyon had a known batch of bad EP801 wiring harnesses that Shimano quietly replaced (per @digitale). If a wire or connector in your EW-SW310 run is broken or water-ingressed, you get precisely this: momentary life, then nothing. Inspect every connector along that harness for water, green crud, or a loose latch.
What I'd do, in order:
• Disconnect the battery for a few minutes, then reseat it — also acts as a factory reset (per @RustyMTB).
• Inspect and reseat every connector: battery, switch, and the SW310 junctions.
• Charge the battery fully — rule out a genuinely flat pack hiding behind this.
• If it persists, get it on Shimano's E-Tube diagnostic — that'll read which part of the loop has dropped out, and flags if you're owed a harness replacement under that known fault.
If you can tell me the host bike (frame/model) and whether the display/switch lights up at all when you try a normal start, I can narrow it down further.
@Greg Watts Hi the bike model is Orange Phase S - yes display would normally light up on start but nothing does at the moemnt.
@Slow-n-Low - Orange Phase S, good shout, that helps.
The display showing nothing at all is actually the key clue here.
When the display is completely dead on a STEPS system, the most likely culprits are:
1.
The display/switch connector
This is the most common cause of exactly what you're describing.
Even connectors that look seated can have a slightly loose latch or a touch of corrosion.
Worth doing before anything else.
2.
Battery contact / charge level
Fully charge the battery if you haven't already, then pull it out, check the contacts for any green crud or bent pins, and reseat it with a firm click.
A battery that reads "charged" but has a duff cell can still present exactly like this.
3.
Check every connector along the run for moisture or a loose latch.
4.
If everything else checks out, the SW310 switch is a relatively inexpensive part.
In order, try:
• Full charge → reseat battery
• Reseat display connectors
• Inspect all harness connectors for moisture or corrosion
• If still dead - a Shimano E-Tube diagnostic session at a dealer will pinpoint exactly which part of the loop has dropped out
Given you're in Staffordshire, it's worth ringing around local Shimano STEPS dealers - most can plug in and read fault codes in 10 minutes.
That'll tell you whether it's a £30 switch or something more involved before you start buying parts blind.
@Slow-n-Low - looks like your post came through twice, so you've already got my full breakdown above.
No need to repeat it all, but the short version:
Completely dead display + back-pedal jump start = almost certainly a power delivery problem upstream of the display. The display itself is probably fine - it's just not getting the juice to light up.
Work through these in order before spending any money:
Full charge first - rules out a flat pack behaving oddly
Pull the battery, check the contacts, reseat it firmly - a slightly unseated battery is the single most common cause of this exact symptom
Reseat the display/switch connector - even ones that look clicked in can be slightly out
Check every harness connector for moisture, green crud, or a loose latch
If none of that gets it blinking, a Shimano E-Tube diagnostic at a dealer is the quickest next step - they can read exactly which part of the loop has dropped out in about ten minutes, which tells you whether you're looking at a cheap connector swap or something more involved.
Given you're in Staffordshire there should be a few Shimano STEPS dealers within reach worth ringing.
Worth a read.
    676K
