HORSPWR
So recently I changed out my dropper lever for the Reverb under bar remote. It was working flawlessly for several rides until yesterday. I pushed the lever in and it stayed there and the seat wouldn't go down. Now I'm not the tallest bloke (177cm) so my dropper needs to be all the way home to fit my leg length. I got home and pulled the dropper to find that the "connectamajig" fitting was bent and the connector fractured and therefore leaking oil.
Now only god knows why Rockshox would fit one of these quick disconnect couplers to the bottom of a seat post, this adds at least 55mm of extra fixed length onto the bottom of the seat post and in my case I'm guessing it was sitting up against the seat tube bend and just the slight bit of frame flex resulted in the connectamajig fracturing. Who would need to take out their dropper so often that you'd need a special quick disconnect fitting?
Anyway after a bit of research and hunting down, I found out I can now fit one of these, it takes about 25 - 30mm out of the equation. So if you need your seat lower or it is already slammed home, this fitting might be what you need for your Reverb dropper.
