Removing Battery on the Rise
Shjay
Kent
I was putting a new cable in dropper post & unfortunately during process must have pulled on cable that connects to EW EN100, have power but display won’t turn on, is it easy to remove battery to find out where other end of the EN100 cable connects inside the bike
I'm in a similar position. You'll need the proper tool to remove the chainring or you'll find it difficult to drop the motor as the chainring obstructs one of the motor bolts. After that evrything is explained in the blue paper.
This is the tool I've just ordered Products | Birzman
All sorted removed forks & accessed at headset top as cable plugs into an adapter which then plugs into the motor
Saw on blue paper plans
Already have tool to remove chainring etc
Cheers
