Reliable hubs?
I've not had to much luck with wheels at the moment.
Nukeproof horizon rear wheel spokes started unwinding after truing. Trek are saying you should try some Loctite on the nipples which might solve the problem. The current rear Stan's Flow EX3 rim / wheel is still straight after 7 months but the ebike hope pro 5 hub ended up failing.
I need to get a rear wheel sorted fairly soon & debating getting another wheel built up with a different hub.
Anyone had these hubs fail fairly quickly DT Swiss 350 / Dt Swiss 240 or Industry 9 1/1 hubs with an ebike ?
I built a set of wheels for my old specialized Fuse and now they are on my Orbea Rise. Velocity Blunt 35 rims laced to a DT Swiss 350 hub, double butted spokes, and brass nipples lubricated with anti sieze. They are working well under my 290 pounds. Have someone build you a wheel.
    Join 43,196
