Rear Tyre Dilemma
HORSPWR
Alice Springs, Australia
Looking to replace my rear tyre soon, tossing up between the Schwalbe Eddy Current but I can only get it in 2.8 wide and the Michelin E-wild rear in a 2.6
I'd rather go for a 2.6 as I'm not a fan of the extra bouncing around you can get from some 2.8s but I'd would settle on the Schwalbe if it's a better tyre and has a fairly stiff side wall and not too bouncy. Currently running a Continental 2.6 on the rear which has been a sold performer and has certainly taken some severe abuse but it's a bit too bouncy and I need bigger knobs for steep gnarly climbs and more grip.
I do have a Maxxis Assagai 2.6 on the front so not sure if I should also consider one of these for the back as well.
Any thoughts on which way I should go?
Apparently Schwalbe are about to increase their range of the Eddy Current with more 2.6 options. sounds interesting to me but not sure of the time lines
Just been through the very same decision process and opted for the E-Wild in 2.8 after reading many positive reviews both on here and elsewhere. I was set on fitting an EC to the back before discovering the E-Wild reviews. I have ordered a Maxxis Assagai 2.6 for the front again after reading glowing reviews. I would of ordered an E-Wild for the front if they were available in 29.
How's the EW in 2.8?
Is the side wall stiff enough to not be too bouncy?
For steep, gnarly climbs & descents where sometimes durability is survival & preferable to saving 200 grams or whatever, I think you’re right - Assegai. 27.5 x 2.50WT DH Casing.
If you prefer to save the weight, same in 2.60 EXO+
