Yes had it just over a week .![]()
R Raymon FullRay 150E 8.0 Electric Mountain Bike Blue/Matt Black
Whether it’s long, tough climbs, technically demanding downhills or easy flow trails: just ride where and how you want! The R Raymon FullRay 150E 8.0 is ready for whatever you throw at it.www.paulscycles.co.uk
Looks amazing. That is incredible value.
Has yours arrived yet, how does it ride?
It's way better than my Cube stereo hybrid race 140. Only gripe was the length of brake hose , nut soon had them trimmed.Just bought the Raymon Fullray 9.0 from Paul’s cycles…sort of spec you get on a 4k+ bike so seems great on paper. How are you liking yours?
Oh and the brake pads, swop them out for Galfer ebike purple ones.Just bought the Raymon Fullray 9.0 from Paul’s cycles…sort of spec you get on a 4k+ bike so seems great on paper. How are you liking yours?
What brakes did you get? Mine has SRAM DB8 not the Magura ones on the site.Oh and the brake pads, swop them out for Galfer ebike purple ones.
Cost around £50 for a full set but worth every penny.![]()
Yes magura, 4 pot on the front, single rear .What brakes did you get? Mine has SRAM DB8 not the Magura ones on the site.
Weird I got DB8s all around. I’ll try those pads, thanks! What kind of battery life are you getting?Yes magura, 4 pot on the front, single rear .
Galfer do pads for shimano , mate put them in his XT 4pots on his Obrea H20 and couldn't believe how much the power increased.
It appears many bike manufacturers started to fit DB8 brakes on their low/medium range offerings.Weird I got DB8s all around. I’ll try those pads, thanks!
Currently getting around 60 miles and mine is chipped with a volspeed v3 so top assisted is around 30mph .Weird I got DB8s all around. I’ll try those pads, thanks! What kind of battery life are you getting?
Also do you know if the display can be upgraded? I see Yamaha does a nicer looking colour one.
Also mine came with Maxxis Dissector tyres which was different the the official specs.
They aren't taped as we would know it , just a tight fitting rim tape , I kept getting a leak at the seams even after a few attempts with different tapes and sealent.Ok thanks! What’s wrong with the rims, never had to use more tape on tubeless ready rims?
I bet on your bike you're number one super guy & you're faster
It's the seam , it's pinned not welded so will leak.Ok those rims are a complete pain to set up tubeless, they basically have no bead which in my view makes them not tubeless ready at all.
Hi i am looking to purchase the fullray 150e 9.0 as a first emtb. Just wanted to know what you think of it and whats it like?Just bought the Raymon Fullray 9.0 from Paul’s cycles…sort of spec you get on a 4k+ bike so seems great on paper. How are you liking yours?
I'll be honest it's better than the Cube stereo hybrid race 140 I had .Hi i am looking to purchase the fullray 150e 9.0 as a first emtb. Just wanted to know what you think of it and whats it like?
really enjoying mine, solid bike. Agree headset and wheels were crap but everything else good. Good range and plenty of power.Hi i am looking to purchase the fullray 150e 9.0 as a first emtb. Just wanted to know what you think of it and whats it like?
They can be fiddly , squirt a bit of WD40 /OIL into the lock bit don't force the key .Hey, anyone know how to remove the battery on these things? Easy to remove the cover and found key hole, key turns but nothing happens. There’s a piece of metal which prevents it from falling out which doesn’t seem to move.
Thanks sorted it, didn’t realise you had to move the kind of thumb turn thing up after unscrewing it. Got it in out of the cold shed now, thanks.They can be fiddly , squirt a bit of WD40 /OIL into the lock bit don't force the key .
Thanks, I don't what year my PW-ST is from but I guess 2022 or later. So perhaps they changed the connector after that.From what I can find out they are interchangeable.l if they are post 2022 production.
