Quietest emtb motors.
Bruizer
How does the turbo levo 4 motor compare to other motors in terms of quietness?
Right, the eternal "which motor sounds least like a kitchen appliance" question. Let's have at it.
The Levo 4's Specialized 3.1 motor sits in the middle of the noise league - not the silent assassin the old Brose Gen 3 was, but nowhere near Bosch CX Gen 5 territory either. Specialized swapped the belt drive for metal gears in the 3.1, which is why it's slightly noisier than the Gen 3 it replaced.
Forum consensus, for what it's worth: • @garethky reckons the Gen 4 motor is very quiet under about 150 watts, making it suitable for group rides without being a distraction
- so in Trail/Eco it's genuinely civilised. • @ricko found the Gen 4 motor quieter under power than Bosch Gen 4, with no rattling downhill. • @RoissyAngel noted a reviewer pointing out the Gen 4 Levo motor's noise stays uniform even when hot, unlike the Bosch SL which gets louder when worked. • But it's not unanimous -
@rew187 reckons the Gen 4 is noisier than Gen 3 even at low assist, with Gen 4 at 10% louder than Gen 3 at 20%.
• And @linkqwd's back-to-back test flagged a higher-pitched, louder motor than Gen 3, with rattle on descents similar to Bosch Gen 4. So where does it sit overall? Roughly:
Quietest → loudest (full-power motors, 2026) • Shimano EP801 - still the quietest mainstream motor under load
• TQ HPR60 - basically inaudible (but it's lightweight, different category) • Brose S Mag / old Specialized 2.2 - silent, but being phased out
Since the bot tagged me, the Brose 3.1 definitely has a noticeable rattle.
It’s well described in Specialized’s official document:
https://support.specialized.com/kb/sp_en-us/content/ECV3-6201/Turbo-Bikes-Motor-Sound-Explained see Gearbox Clatter/Movement Sound
You can find many statements on this forum saying there’s no rattle on descents. Some people might not notice it or simply don’t mind it. Maybe it doesn’t appear much on smoother flow trails, and some people may idealize the bike.
But the rattle is 100% there by the motor design.
Since the bot tagged me, the Brose 3.1 definitely has a noticeable rattle. It’s well described in Specialized’s official document: https://support.specialized.com/kb/sp_en-us/content/ECV3-6201/Turbo-Bikes-Motor-Sound-Explained — see “Gearbox Clatter / Movement Sound” You can find many statements on ...
@linkqwd - fair cop, and you're right. I called out @ricko saying there was "no rattle on descents" from the 3.1, and that's exactly the sort of claim you're correcting. Specialized's own support documentation acknowledges the Gearbox Clatter / Movement Sound on the Brose 3.1 - this isn't forum speculation, it's in their official KB. So the rattle is documented, confirmed, and I should have been clearer about that rather than presenting "no rattle downhill" as a credible counterpoint.
What actually seems to be happening, based on the community evidence: • The rattle exists. Specialized says so themselves.
• Individual sensitivity varies enormously. Some riders genuinely don't notice it - not because they're wrong, but because humans are remarkably good at filtering out noises they've decided not to care about.
• Trail surface matters. On smooth flow trails, you may never notice. On technical, rooty descents, it's there.
• It reportedly worsens over time. @PaulH2B has noted that Specialized officially acknowledge the clattering increases over the motor's lifetime - which explains why newer owners sometimes report less rattle than those further into ownership.
Given that you're running a Gen 3 Levo with the 2.2 (belt-driven, the actual quiet one), you've got a useful reference point. The 3.1's metal gears were always going to trade some of that silence for the extra torque headroom.
    668K
