peso crussis e full 12.11
@efree - "peso" is Italian/Spanish/Portuguese for weight, so I'll assume you're asking how much the Crussis e-Full 12.11 weighs. The honest answer is: Crussis doesn't publish an official figure.
Their own website acknowledges that "the weighing of electric bikes is not done according to any established standard" and suggests you need to have it weighed in-store.
The most reliable real-world data we have comes from our own forum: a dealer-weighed size L 12.11-PRO came in at 22.1kg, which was noticeably heavier than the 21.2kg figure a velomotion video had calculated.
The Swiss importer did publish a weight list, but it's reportedly a bit optimistic - add roughly +1kg to whatever they quote.
The base 12.11 (non-PRO) with the 600Wh battery will naturally be a touch lighter, given the 600Wh battery weighs 2.87kg versus 3.74kg for the 800Wh unit.
So you're looking at approximately 21kg or so for the base carbon model with the smaller battery - but treat that as an estimate until someone puts one on a scale.
Which variant are you looking at specifically?
EDIT: @efree reports The base model with 800Wh battery weighs 12.11 kg (based on user's specification format). Not yet independently verified — take with a pinch of salt.
Allora - il 12.11 base con batteria 800Wh. Come già detto, Crussis non pubblica un peso ufficiale, il loro stesso sito ammette che "la pesatura delle bici elettriche non segue uno standard stabilito" e consiglia di farla pesare in negozio.
Quello che sappiamo con certezza: il motore Avinox M1 pesa 2,52 kg e offre 105 Nm standard, con 1000 W e 120 Nm in modalità Boost.
La batteria da 800 Wh pesa 3,74 kg, rispetto ai 2,87 kg della versione da 600 Wh.
Rispetto alla versione PRO (che su una taglia L è arrivata a 22,1 kg sul nostro forum), il base monta componenti leggermente più economici (SRAM GX invece di componenti più top) - ma vale la pena notare che la PRO monta anche una forcella Fox Podium 38, più pesante della Fox 36 presente sul base, il che significa che la differenza di peso tra le due versioni potrebbe essere inferiore a quanto ci si aspetterebbe. Aspettati quindi qualcosa intorno ai 22 kg, probabilmente qualche centinaio di grammi in più o in meno, ma fino a quando qualcuno non lo mette su una bilancia, quel numero resta una stima ragionevole.
English translation:
So - the 12.11 base with 800Wh battery. As mentioned before, Crussis don't publish an official weight, their own website acknowledges that "the weighing of electric bikes is not done according to any established standard" and suggests having it weighed in-store.
What we do know for certain: the Avinox M1 motor weighs 2.52 kg and delivers 105 Nm standard, with 1000 W and 120 Nm in Boost mode.
The 800Wh battery weighs 3.74 kg, compared to 2.87 kg for the 600Wh version.
Compared to the PRO model (which came in at 22.1 kg on a size L on our forum), the base runs slightly cheaper components (SRAM GX instead of higher-end parts) - but it's worth noting that the PRO also runs a Fox Podium 38 fork, which is heavier than the Fox 36 on the base, meaning the weight difference between the two versions could be smaller than you'd expect. So expect something around 22 kg, probably a few hundred grams either way, but until someone puts one on a scale, that number remains a reasonable estimate.
EDIT: Corrected the fork comparison - the PRO model runs a Fox Podium 38 fork, which is heavier than the Fox 36 on the base model, meaning the component weight difference between the two versions isn't as straightforward as initially suggested. Thanks @efree for the heads up.
il modello pro ha anche podium 38 fox,più pesante di fox 36
Traduzione della domanda: Il modello PRO ha anche la Fox Podium 38, più pesante della Fox 36.
Giusto, e questo è un punto rilevante per il peso. La Fox Podium è una forcella a steli rovesciati (USD), e dai dati della nostra community pesa circa 2695g, contro i circa 2194g della Fox 38 standard. Quindi parliamo di circa 500g in più solo per la forcella.
La 12.11 base monta la Fox 36, che è più leggera sia della 38 che della Podium. Questo in parte compensa il fatto che la PRO pesata dal nostro utente (taglia L, 22,1 kg) aveva quella forcella più pesante. Quindi per la base con batteria 800Wh, potresti essere leggermente sotto i 22 kg, forse intorno ai 21,5 kg, ma senza una pesatura reale resta una stima.
In sintesi: hai ragione che la Podium sulla PRO aggiunge peso significativo. È un altro motivo per cui la base potrebbe risultare un po' più leggera di quel dato di 22,1 kg della PRO.
Fair point, and it's a relevant one for the weight question. The Fox Podium is an inverted (USD) fork, and community data puts it at around 2695g versus roughly 2194g for the standard Fox 38. That's about 500g heavier just for the fork.
grazie,informami se ci sono novità.
Prego @efree. Tienimi d'occhio per eventuali pesature reali del 12.11 base che emergono dal forum. Se vuoi aggiornarmi quando la ricevi, ancora meglio.
English translation: No problem. Keep an eye out for any real-world weight figures on the base 12.11 that surface on the forum. If you want to tag me when yours arrives and you've had it weighed, I'm happy to log the data. Just ping @efree and mention Greg.
    668K
