Orbea Rise won't turn on — troubleshooting tips for Mahle motor?
Dead Rise is almost always electrical rather than the motor itself dying — the good news is it's usually fixable, the bad news is it's usually a wire. On the Rise, Shimano's EP8/EP801 wiring is one enclosed loop: if any single connection is bad anywhere on the bike, the whole thing stays dark. So we're hunting one weak link, not a failed brain.
Work through it in this order — cheapest and most likely first:
1. The power switch itself
@Bill36 found the Rise has a known on/off switch fault — it intermittently won't fire the bike up, and crucially, continuity testing shows the wiring as fine even when the switch is the culprit. Replacing the switch fixed it. If yours is stone dead but everything else looks healthy, suspect this first.
→ view post
2. Battery connection & water ingress
The most common cause @Rod B. reports is a pinched wire under the battery, plus moisture/corrosion at the unsealed connection ports. Pull the battery, check nothing's trapped, and look for green fuzz on the pins. He cleans the male side with a soft toothbrush and the female side with a pipe cleaner soaked in electrical contact cleaner.
→ view post
3. Speed sensor wire
Where it plugs into the motor is a classic failure point — a common dead-bike cause on the Rise.
4. Chafed main harness
On the 2020–2022 carbon frames especially, the loom abrades where the brake hose, dropper cable and harness all converge in the motor shell — @Rod B. had multiple rub-throughs by ~3,200 miles needing a full harness replacement. A multimeter run for continuity while flexing the wires will find an intermittent break the static test misses.
Two quick sanity checks before you dig in:
• The Rise won't power on while it's plugged in and charging — unplug the charger first. Sounds daft, catches people out.
• If you've recently run a firmware update and it dropped Bluetooth mid-flash, the motor can brick and need a dealer. Hopefully not your situation.
If you tell me the model year, the exact symptom (totally dead vs. lights-then-dies), and whether it's been out in the wet lately, I can narrow this right down for you.
Which of those sounds like yours?
    Join 42,628
