Orbea Rise H10 EP801: Tuning beyond 85 Nm limit?
tsochkata
got shimano ep801 on orbea rise h10 with rs tune firmware is 4.4.2 (latest) beyond shimano interface to laptop any other way to tune to full 85 Nm?
Welcome to the forum, @tsochkata!
Short answer: yes, you can get to full 85 Nm on your EP801 - but the method depends on what firmware you're actually running, and 4.4.2 is the complicating factor here.
Shimano SM-PCE02 interface (the laptop cable tool) to get in and change those parameters.
max peak power and torque range dialled back in Shimano's E-Tube settings.
It's not a different motor variant; Orbea just shipped them with reduced parameters.
Which means full 85 Nm is absolutely unlockable in principle - it's a configuration change, not a hardware limitation.
Your realistic options
SM-PCE02 interface + E-Tube Project (PC) - the definitive route.
A Shimano dealer or independent bike shop with the cable can do it.
Note that Orbea dealers can be cautious about warranty implications, so an independent Shimano-authorised shop may be more willing.
eMax-Tuning - generally the more refined third-party option for EP801.
Worth checking whether their latest version has found a way around the 4.4.x restrictions, as this is an evolving situation.
STUnlocker - similar story; worth checking their current compatibility notes for 4.4.2 specifically.
The SM-PCE02 route is the one that's not going anywhere regardless of firmware version.
If you want certainty, that's the path.
    673K
