Newbie with headset reducer issue
rayke
Hi all,
I'm new to both downhill biking and emtbs. I recently purchased a Norco Fluid VLT A1 with the oversized 1.8" steerer. The OEM Rockshox Silver 35 fork was inadequate for my weight (220lbs) so I swapped it out with a Rockshox Domain with 1.5" steerer and FSA Crown Race 1.8" Reducer to 1.5". The reducer works fine when riding on the flats but isn't when I hit the bumps. I've already overtorqued the stem cap bolt to 10nm but there is still some slop going over roots, rocks, etc.
Any other work arounds to get a firmer feeling fork?
TIA!
Hi all,
TIA!
I know these bikes s I have a gen2 Range Vlt that has the same headset (1.8" lower bearing.)
I've not had issues with the headset knocking but wonder if your stem-cap is not tightening against the bearing / stem spacers but actually tightening against the steerer-tube so needing a little more hight of the spacer pack?:unsure:
^^ easily checked as the steerer-tube will leave a 'whitness mark' on the underside of the stem-cap🧐
Thanks for the suggestion Rich. I'll check that out!
Thanks Zed, I'll check that out!
    668K
