Levo SL Gen 1 New SL
Wow. Think I may be tempted to sell my 2019 Levo Comp and get the new SL. Am taking a test ride in couple of weeks. I have always thought my eMTB was a bit excessive that took away some of the swetty fun! Normally I only ride in eco or a reduced trail mode. Sometimes turbo on way to trails (10km flat tarmac ride) and back home. I still ride conventional MTB also for the challenge and workout but cart that to the trails on back of car. I wonder if the SL hits the sweet spot?
I wonder how loud the motor is? It seemed like it might be a bit on the loud side based on what I heard on the Video. Kind of makes sense given it is gear driven and not belt driven like the Brose.
Sounds like this is for you
Yep, it's definitely louder at times. The brose is near silent. It's a high pitch whine like no other ebike imo. You do notice the bike is mechanical. Whereas the you can be convinced it's just you on steroids. It's gonna bug me a bit until I get used to it, but the fun on the flat and downs should easily outweigh it. #earplugs lol. It's nowhere a e8000/Bosch/yam etc
Motor noise is a deal breaker for me. When I pass people I don't want them to figure out that I am on an ebike until I am in front of them. They might not let me pass if they can hear me coming.
Also, I respect the technology advancement but they really got everything right on the first Levo. Trail side battery swapping is a must for me. I ride in the winter to and you really need a lot of power when the temperature is below freezing.
I kinda wonder if the target market for this bike is for the retired (and rich) physically fit mountain biker. Keep in mind, I'm not knocking the bike. It just isn't a good fit for me. I like my 52 lb tank with plus tires and aluminum motor box. Cheers
after looking though all the specs ... i think it only really makes sense if you pony up for the carbon models ... the alloy with a range extension is so close to weight to the levo that Im not sure there would be any real advantage?
Take a 2020 Levo S-Works with same equipment than the SL and 500Wh battery => 19,6kg
Take a Levo SL with extender
18, 2kg
Less power, less autonomy and flexibility for only 1,4 kg, non sense for me
i would be tempted by frame only then build it up with a coil and fox 36 but i don't really want to pay for a high end cassette that will just get replaced with an slx or whatever. I guess a base carbon would work but i like the dt star ratchet hub, first world problems
