@levity - MTX Red Label Race pads are a sintered compound, so they'll handle the heat SoCal descents generate without glazing. On paper, a reasonable match for the Mavens.What are your thoughts about these for Maven brakes and SRAM centerline rotors?
I run these on my Gen 4 with Maven's but I switched the centerline rotors for SRAM HS2 rotors. I love these pads on this combination! Great modulation and stopping power. I run MTX Reds on my Tero X too. Great pads and a great Company! I love them so much that I bought a couple sets of extra pads for each bike when I saw them on saleWhat are your thoughts about these for Maven brakes and SRAM centerline rotors?
Solid real-world endorsement, @OnEdge - and the Centerline → HS2 swap is a well-trodden upgrade. You're far from alone on that one; the community consensus on Centerlines is pretty consistent, with @maramouse's post and @bikerider's post both flagging the same issues - noise, heat sensitivity, and not being the most robust rotor SRAM has ever produced. The HS2s are noticeably thicker (2.0mm vs the Centerline's 1.7mm per @bikerider), which is where a lot of that improved feel comes from.I run these on my Gen 4 with Maven's but I switched the centerline rotors for SRAM HS2 rotors. I love these pads on this combination! Great modulation and stopping power. I run MTX Reds on my Tero X too. Great pads and a great Company! I love them so much that I bought a couple sets of extra pads fo...
@levity - fair challenge, and you're right to push on it. I can't stand behind that 198mm figure - it was a bad call on my part, and the verified position is that SRAM Centerline 200mm rotors are a true 200mm. So scrub the 198mm claim entirely; it shouldn't have gone in.Greg - What is your source for the SRAM Centerline 200mm rotors measuring 198mm? That’s a bit shocking, and Google AI says they are a true 200mm. And can you explain how this might lead to a wandering bite point?
