Levo Gen 2 Monarch on Levo 2020 with Megneg developed slight inner play
grim007
34
25
Israel
Hey
The rear shock on my levo developed a slight play. If I pull the bike upward by top tube I can feel a slight play in the shock with my fingers. Like 1mm movement.
This is definitely not bushings because its coming from inside the shock.
It started few weeks ago, at first I thought my headset was loose and double checked all the bolts. Today I finally found the issue.
Anyone encountered this? I will probably go to the sram service center for this, but if its a small easy home fix I'd rather not spend time without my bike for few days until they fix it.
ebikeZA
286
142
Cape Town
its the weight of the bike affecting the larger Neg chamber ... same issue they had with Lyrics that would sag into the travel when just standing there ...only a few mill . As far as im aware not really a issue ...but I could be mistaken
grim007
34
25
Israel
It was serviced by rockshox warranty.
Apparently its a common issue in 2019 models with some internal bolt getting loose inside.
524K
