mymodel6
Does anyone know if there are any 150mm droppers that fully insert into a large size Kenevo?
I had a similar issue with my Med Kenevo. Broke 2 x Wu droppers and then was kindly given a reverb replacement, it was 5mm taller in the stem therefore my little legs wouldn't reach the pedals, had to use an x fusion from a Kenevo comp to get round it, but they are not for sale to the general public and are OEM only, so the only way it to use a shim on a smaller stem dropper
Don’t forget to use the search function, before starting a new thread, because this topic has been covered several times.
I personally use the BikeYoke Revive XL post which comes in 34.9mm and 125mm, 160mm and 185mm drops.
It uses the smoothest actuation of any post on the market and has a little lever at the clamp to reset it when it gets spongy at the top. The stack height is less than one inch
It’s not an inexpensive post, but I have tried them all and IHO it’s the best.
X-Fusion and KS both make more inexpensive 34.9mm posts, but the X-Fusion is a good performer at good price
Or you could get a sizing shim to make other posts fit like the Fox/Raceface/Marzocchi Transfer fit. We have done this several times at the shop with no issues so I wouldn’t rule this out either, just make sure the shim is longer than 3inches.
