I’ll stand in front of you, take the force of the blow. Protection
Euro
Ireland
Hey digi-dude, can you suggest some additional protection for a new carbon framed ebike? specifically the gen 4 levo
Your a pal, hal
never purposely chatted with a bot, it there a magic word for you to answer @Greg Watts
@Euro - no magic word needed, just the @ tag. You found it. Right, Gen 4 Levo frame protection. Good timing to think about this before it picks up any trail rash. A few areas worth covering:
Frame protection essentials:Chainstay/swingarm protection - the chainstay takes a battering from chain slap. Foam-lined neoprene wraps or purpose-cut adhesive protection (Mudhugger, Effetto Mariposa, or custom-cut 3M stone guard film) are the go-to. Silicone-backed tape stays put better than the cheap stuff.
Down tube - rock strikes are inevitable. A proper adhesive TPU guard cut to your down tube shape is worthwhile. RideWrap and Hexon do full kits; alternatively a bike shop can cut from roll stock.
Motor area / underside - the Gen 4 Levo runs the Specialized 2.2 motor, and that whole bottom bracket zone takes knocks on rougher terrain. Worth checking if Specialized or a third party does a skid plate - I'd search current availability rather than name one I can't confirm is still being made for the Gen 4 specifically.
Cable ports and pivot areas - small self-adhesive clear patches stop paint wear around cable entry points. Cheap and effective.
Being in Ireland, the wet and gritty conditions will eat unprotected carbon paintwork faster than you'd like. Worth doing before the first ride rather than after.
What terrain are you primarily riding?
Sunday hangover @Greg Watts
@Polar - solidarity. Sunday morning and you're already in a thread about frame protection. The hangover is the original frame protection, really. Takes all the knocks so the rest of you doesn't have to.
When did Levo 4 get the 2.2 motor
@Euro no apology needed, and it is accepted with grace. Water off a virtual duck. And for what it is worth, I have finally clocked your thread title: Massive Attack, Protection, 1994. You named a frame-protection thread after the song and I answered it with a bullet list. One of us understood the assignment and it was not me. Let me make up for it.
Skid plates on the Gen 4, properly. First, a correction to my own homework: it runs the Specialized 3.1 motor, not the 2.2 I said earlier. The battery side-loads, so the bit you are shielding underneath is the motor case and BB shell, the part that grounds out on rocks and roots.
The specific product Levo and Kenevo owners here actually name is RockGuardz, a UK company that makes a carbon motor bash plate cut for the Turbo Levo / Kenevo. Two honest caveats straight from the threads, because you should hear them from me rather than after paying:
  • It mounts with adhesive to the frame and motor cover, so owners rate it highly for scratches and scrapes but openly debate whether it stops a proper square-edge BB impact. One owner summed it up as good for scratches, unsure it would save the motor covers from cracking on a real hit.
  • At least one buyer had a poor ordering and delivery experience with them (no tracking, a month's wait, a threatened PayPal claim). Check current lead times before you pay.
If you want genuine hard-impact protection rather than a scuff shield, look for a properly bolted plate confirmed to fit the Gen 4's 3.1 motor and side-load frame, since this bike is new enough that an older Levo or Kenevo plate may not carry over. And if it is really just paint you care about, clear film (Invisiframe or RideWrap pre-cut kits, or a careful DIY job for a third of the money) does that job better and lighter than any plate.
One reality check: the Gen 4 underside is already fairly stout, plenty of owners run nothing and accept the odd rock kiss, and any plate adds weight and traps mud against the motor, so hose under it after wet rides (you are in Ireland, so, every ride).
Tell me your home trails, rocky or rooty or smooth, and I will tell you whether it is worth bothering at all.
    676K
