How do you adjust mounting hardware spacing for a horizontal Bosch Powertube 625 in the...
The spacing you're chasing depends on which battery capacity the frame was designed around, because Bosch PowerTubes come in different lengths — a 625Wh (3.5kg) pack physically occupies more of the downtube than a 400 or 500. So the "adjustment" isn't really you dialling in a gap; it's fitting the correct spacer/adapter kit for the pack the frame is running.
A few things worth pinning down before you touch anything:
1. Frames are pack-specific, not infinitely adjustable. Most Bosch downtubes take a defined battery length with a matching mounting bracket and locking mechanism. If you're swapping between capacities, that usually means a different mounting plate kit rather than sliding the existing hardware. @Rando_12345 noted the Bosch 600Wh battery needs its own mounting plate kit (available via ebike24.fr) — the same principle applies across capacities: the bracket is matched to the pack, not adjusted to it.
2. Which mount are we talking about? There are two distinct fixings people mean by "spacing":
• The battery lock/latch and any anti-rattle spacer that holds the pack snug — this is the one you can genuinely adjust or shim to kill movement.
• The motor mounting plate bolts, which set motor position, not battery spacing. Those are torqued to 13–15Nm and need a T25 Torx Plus Security bit — don't loosen these chasing a rattly battery.
3. If the goal is stopping a 625 rattling — that's the common reason people go poking at downtube spacing. The fix is usually the correct foam/rubber spacer at the base of the tube or a properly seating latch, not repositioning the bracket. A pack that moves is almost always a worn or missing anti-rattle pad rather than a spacing setting gone wrong.
The honest snag: Bosch downtube integration is frame-manufacturer specific. Bosch supplies the motor, battery and lock, but each brand designs its own cradle, spacers and retention. So the exact hardware and any adjustment procedure lives in your frame maker's manual, not Bosch's — the part numbers and shim arrangement won't be universal.
If you tell me the actual bike (brand and model year) the 625 sits in, I can be far more specific about the spacer kit and whether that frame even allows a capacity swap — some do, some are locked to one pack length. What's the frame, and is this a rattle you're fixing or a battery swap you're planning?
Cannondale Mavaro Neo 3 2024
Good to know the actual bike - and worth flagging straight away: the 2024 Moterra Neo 3 is the standard alloy Moterra Neo, not the carbon Moterra Neo LT that came in for 2025. They're different frames with different battery mounting, so I don't want to hand you spacer numbers from the wrong bike.
Here's the honest state of play: I don't have Cannondale's exact downtube spacer/bracket part numbers for the Moterra Neo 3's 625Wh mount in what I can verify, and this is genuinely one of those details that only lives in Cannondale's own service documentation - the battery cradle, foam spacers and any capacity-specific bracket are proprietary to that frame, not something published in a geometry chart or spec sheet.
What I can tell you with confidence:
• The 625 sitting in the Neo 3 is the correct spec for that model - you're not dealing with a mismatched pack.
• On Cannondale's Moterra Neo platform, the battery slides in on rails and locks via the bottom latch; there isn't a rider-adjustable "spacing" in the sense of shims you dial in yourself - any gap is normally closed by the moulded foam pad bonded to the tube, not loose hardware.
• If yours has developed play, that pad degrading or coming unstuck is the far more common cause than the mounting bolts needing repositioning.
So - is this a rattle you're chasing, or did you actually pull the pack out and find loose mounting hardware in there? That'll decide whether the fix is a replacement anti-rattle pad from a Cannondale dealer, or something has genuinely worked loose and needs a torque check.
Where would you shim the battery?
Lock or plug-side, somewhere else?
Where would you shim the battery? Lock or plug-side, somewhere else?
If you're going to close a gap, do it at the lock end (the base of the tube), not the plug/connector end.
The reasoning: the pack locates at the top against its latch and drops down onto the connector at the bottom. The connector side isn't a place you want to be packing shims - those spring contacts need to seat cleanly and squarely, and anything jammed in there risks poor contact, arcing or a bent pin. That's the one end to leave well alone.
Where movement actually shows up is fore-aft or side-to-side rattle along the length of the pack, and the cure is a thin strip of the right material against the flat face of the battery or the tube wall - closed-cell foam or adhesive-backed rubber (the sort of self-adhesive weatherstrip/anti-rattle tape people use for exactly this). You want it just thick enough to remove the knock without fighting the latch when you close it. If you have to force the lock, you've overdone it - back off to a thinner strip.
Two honest caveats, given this is your commuter frame rather than something I can pull a shim spec for:
• Shimming is a symptom fix. If the pack has started moving, the usual culprit is the factory anti-rattle pad having compressed or come unstuck - worth a look before you add material, because refreshing that pad is the "proper" repair.
• Don't shim to compensate for a worn or loose lower bracket. If the latch itself or the mount has play in it, packing foam around it just hides a fixing that wants sorting - that's a dealer job on a Bosch commuter system.
So: lock/side/base end for foam, never the plug end. What are you finding when you pull the pack - spongy old pad, or something actually loose in there?
Any additional considerations when the lock side is at the bottom? With gravity helping reduce contact security?
Good catch - and it flags a contradiction in what I told you earlier, so let me sort that out first.
Correction: on the Mavaro Neo, the lock isn't at the bottom. Cannondale's own manual for this bike describes the release tab as sitting on the "upper part of the battery," with the pack tilting out from an upper mount - and the electrical socket engaging when you insert the lower portion during fitting. So it's latch-at-top, connector-at-bottom. When I said "shim at the lock end (the base of the tube)" a couple of posts back, that line doesn't square with what I'd also said about the latch living at the top - my mistake, and the manual settles it: top = mechanical latch, bottom = electrical connector.
So to your actual question - with that layout, gravity isn't working against contact security at the connector, it's helping it. The pack's weight pulls it downward, which presses it more firmly onto the bottom socket rather than lifting it off. Where gravity IS working against you is at the top: the latch/hook is the thing constantly fighting the battery's weight trying to drop it out, so that's the wear point over years of use, not the connector end.
Practical upshot for you:
• If you get an intermittent power cut, suspect the top latch/hook first (wear, spring fatigue, or the release tab not fully re-engaging) rather than the bottom connector - gravity's on the connector's side, not against it.
• Any shimming to quiet rattle should still go where the pack has clearance to move, which on this frame is more likely along its length rather than jammed at either terminal end.
Given this is a manual detail rather than something I'd trust from memory alone, worth doing a visual check next time the pack's out - see if the upper tab/hook shows any play before you go hunting for foam.
No, the locking latch is at the bottom, the electrical connection is at the top
Fair enough - that flips the picture back the other way, and it's on me for going two rounds on this without pinning it down first. Sorry for the yo-yo.
So: latch at bottom, connector at top. That means your original instinct was right - gravity is working against contact security, not for it. The pack's own weight pulls it downward, away from the top connector, while the bottom latch is what's fighting that weight to keep everything seated. So:
• The top connector is the one gravity can compromise - if a latch adjustment or a worn latch lets the pack drop even slightly, that's the connection that loses pressure first.
• The bottom latch is doing constant load-bearing work holding the pack up against its own weight, so that's your wear point over time - spring fatigue or a hook not fully engaging will show up here.
• Any shimming to kill rattle should go where the pack has physical play along its length, and specifically you want enough snugness that the latch is genuinely holding the pack UP against the connector, not just resting there - a loose lower latch on this layout isn't just annoying, it directly risks intermittent power cuts at the top connector.
If you get a dropout, check the bottom latch engagement and the top connector seating first, in that order - and if there's any doubt about latch wear, that's a Cannondale dealer check rather than something to shim around.
Good luck with it, @locomoto - give me a shout if the pack's still playing up after you've had a look inside.
    Join 42,884
