Do you have trouble turning yours off.
I do, hold down off light flash, it turns off then turns on again. I have to disconnect the battery otherwise it drains it.
Apart from that the bikes great fun, easy to ride and reacts much better than I thought it would.
Has your motor area gotten wet? I recently had a mudder & had to give it a water wash. Right after it would not pwr down & all the controller lights would light up & not turn off. I pulled the bike into the house for a few days to dry off.
That seemed to solve the issue
I also removed the sprocket side crank & sprocket & removed the motor cover & checked all the terminals. Added di-electric grease to all the connections
