My Levo headset always has play. I’ll fix it and get the play out and one ride later there is play. Is this from the swat tool or from the -1 cup or jUSA crappy from specialized.
@Anima1ctrl - welcome to the forum. This is a well-documented Gen 3 Levo headache, and you're not imagining it. The recurring play is almost always one of three things:
1. The lower bearing cup is loose in the head tube The Gen 3 lower cup can spin or migrate slightly even when correctly pressed. On some frames, particularly early alloy builds, the cup-to-head-tube fit is marginal from the factory. Tightening the stem won't fix a cup that isn't properly seated. The community fix that's held up is
Loctite 641 retaining compound with activator primer on the cup OD - locks it without making it unserviceable.
Forum members have recommended exactly this.
2. The -1° angled cup The angled geometry cup is the more common culprit. It reduces the bearing contact footprint and is more prone to fretting.
Switching to the 0° cup has resolved the play problem entirely for some owners - obviously at the cost of the slacker geometry setting.
3. Insufficient steerer tube insertion depth If there's too much spacer stack and not enough steerer in the stem, play is almost impossible to eliminate.
Cutting the steerer slightly and adjusting spacers has sorted it on a few Gen 3s.
The SWAT tool - stored in the head tube on S-Works, removed from Comp Alloy as a cost-cutting measure -
is sometimes cited as a rattle source but wouldn't cause bearing play itself.
If Loctite 641 and cup re-seating doesn't hold, a
Hope headset has been reported to eliminate the issue entirely on Gen 3 - better seal and more positive cup retention than the FSA/Specialized OEM unit.
Worth looking at if you're going nuclear on it.
What year is your Gen 3, and are you running the -1° cup?
