Hello from Palm Springs, CA.
PDS
Palm Springs
new owner of a 2020 Levo Turbo comp. mtn biking for over 30+ years.
two great rides so far and only 2 issues. If someone can point me to where I can find more info
Levo is a XL. is there a way to have the dropper seat post only rise to a certain height?
Also, dropper release lever rubs on my thumb. anyway of moving it on the handle bars. it's connected to the brake lever and has limited movement.
thank you
Alright, PS Calif. Im in So. Cal as well. Hey our bikes have that same dusty look vs most of the others here covered in English mud (haha)
Not sure if i follow you on your dropper post height? You have to lower or raise it in the frame to get the height right
Cheers, Joe :coffee:
Greetings Joe,
was told that the seat post could not be lowered anymore down the seat post frame.
when the seat is at the top, it still feels a little too high.
want to be able to raise to the height that I like and then lower on downhill
hope that helps
Ok, i understand. I almost have the same issue. My dropper is a low as she goes. You will need a shorter dropper for sure
    668K
