aw113sgte
On a few off camber rocks/roots I was feeling the bike squirm a bit. Took a look and noticed the rear end is flexing enough to make contact on those rougher hits. The tire is offset to the rubbed side just a hair, no more than 1/8" (3mm). Spoke tension is pretty good, need to check suspension pivots next. I will dish the wheel over slightly.
This is on an XL and I'm 210lbs (95kg). Anyone else experienced this?
