German emtb rider
onkelshort
26
26
I am loving my new Levo SL and found some threads in this forum with several individual builds. I like to upgrade my bikes all the time, so looking forward for some inspiration ;)
onkelshort
26
26
Latest version
First try with the levo SL.
Almost forgot: my Rotwild r.e1+ ? nothing original on this one any more but frame, motor and battery.
onkelshort
26
26
Nabend, komme aus Bochum. Das ist vllt ein bisschen weit um Mal ne Runde zusammen zu drehen ? bin nach wie vor vom SL total begeistert.
Cooles Bild ?
onkelshort
26
26
In my point of view you have 160mm travel anyway with 2.5mm additional stroke. Stumpi has 50mm which equals 140mm, levo sl has 52.5mm which is 150mm and so I guess 55mm should be around 160mm anyway. Leverage ratio is always the so, right?
The cc IL coil has bottom out rubber seal around the piston rod, which works pretty well. 150mm is good for now.
Does the link improve riding noticeable? Seems pretty expensive.
I run 160mm fork as well. Cannot say that the bike tends to flip in uphill. And I am running low position for the damper. So cannot complain ?
But thanks for the hint!
