Geometry table for 2019 Focus Jam2
EMTB Pro
I bought a new Focus Jam2 9.6 NINE 2019 in January of that year.
Will you provide the geometry table for that year of bike please? 2018 won't do because Focus increased the suspension travel from 2019 onwards.
PS: I know that you will know Greg, but for those that don't that bike was a carbon fibre frame 29er.
I bought a new Focus Jam2 9.6 NINE 2019 in January of that year. Will you provide the geometry table for that year of bike please? 2018 won't do because Focus increased the suspension travel from 2019 onwards. PS: I know that you will know Greg, but for those that don't that bike was a carbon fibre ...
Right, @steve_sordy, I've had a good rummage through my database and the wider web for you, and I'll be honest: I can pull the key specs but the full geometry table for the 2019 Jam² 9.6 NINE specifically is proving elusive in complete numerical form. Here's what I can confirm.
The 2019 Focus Jam² 9.6 Nine was available in sizes S, M, and L, ran the Shimano Steps E8000 motor (70Nm, 250W), and had a 378Wh internal battery.
You're correct about the carbon fibre; the frame used a carbon front triangle with a 7005 hydroformed aluminium rear triangle. Rear travel was 150mm with a RockShox Deluxe R shock (210x55mm), and the fork was a RockShox Revelation RC.
That's the bump up from the 2018 models' 140mm that you mentioned. For geometry reference points, the head tube angle was 66.5° and the chainstays were notably short for a 29er eMTB of that era, which was a key part of the Jam²'s character.
The bike used Focus's F.O.L.D. (Focus Optimized Linkage Design) suspension and had geometry adjustable via a flip chip at the rear dropout.
However, I don't have a verified, size-by-size geometry table with reach, stack, wheelbase, seat tube angle, BB drop and so on for your specific 9.6 NINE 2019 model. Geometry Geeks has partial data (stack/reach pairs) for the 2019 Jam² range, and Vital MTB lists the bike but doesn't surface the full table in a way I can pull cleanly. Your best bet for the complete numbers would be checking geometrygeeks.bike directly (search "Focus Jam2 9.6 Nine 2019") or the Focus archive. The 9.6 and 9.9 NINE shared the same frame and geometry, so the 9.9's table would be identical if you find that first.
Apologies I can't just slap the full table down for you. If you can dig out the original spec sheet or manual from Focus, I'd happily add it to my records so the next person asking doesn't hit the same wall.
I thought it was just me that couldn't find it! That my Google-fu was failing me.
Thanks for the link to geometry geeks. And thanks for the tip that the 9.6 and 9.9 NINE shared the same geo.
I thought it was just me that couldn't find it! That my Google-fu was failing me. Thanks for the link to geometry geeks. And thanks for the tip that the 9.6 and 9.9 NINE shared the same geo.
Not just you, @steve_sordy. Focus weren't exactly generous with their geometry documentation for that era, and the Jam² seems to have slipped through the cracks of most of the usual archive sites too. Your Google-fu is intact.
Hopefully Geometry Geeks fills in the blanks for you. And if you do manage to dig out the full size-by-size table from an old manual or spec sheet, send it my way and I'll get it into my records. Save the next person from the same wild goose chase.
Ah, No!
Nothing on geometry geeks except manual bikes, just Focus Jam, not Jam2.
So I had another go at the Focus website.
I found their archive. :)
JAM² Carbon | 2017 - 2021 Shimano | FOCUS Bikes
And then with almost fevered anticipation, downloaded the correct file.
And got a single page of summarised blah, blah, blah.
No geometry at all. :(
Not your fault if not even Focus don't keep it!
Howver, I do know that sometimes in bike reviews, the author shows the geometry. Did you look in any of the various reviews?
Ah, No! Nothing on geometry geeks except manual bikes, just Focus Jam, not Jam2. So I had another go at the Focus website. I found their archive. :) JAM² Carbon | 2017 - 2021 Shimano | FOCUS Bikes And then with almost fevered anticipation, downloaded the correct file. And got a single page of summar...
Good question, @steve_sordy. I didn't dig into individual reviews last time, so let me do that now. Right, @steve_sordy, I've now gone through the reviews and database sites specifically, and here's where we are.
The bad news: none of the published reviews I can find (BikeRadar, E-Mountainbike Magazine, Vital MTB) include a full size-by-size geometry table for the 2019 Jam² 9.6 NINE. They all list specs but stop short of the actual geometry chart. Focus really did make this disappear into the ether.
The interesting lead: Geometry Geeks does actually have the 2020 Jam² 9.8 NINE Shimano listed, with 3 sizes showing stack|reach pairs of 618|410, 618|430, and 636|445.
Now, the 2019 and 2020 Jam² NINE shared the same frame platform (Focus didn't update the chassis until 2021), so those numbers should be identical to your 2019. That said, it's only stack and reach, not the full table, and I can't state that as gospel without verification.
Interestingly, the 2020 Jam² 6.8 NINE Bosch entry on Geometry Geeks notes that the geometry table is with the flip chip in lower position, and if placed in high, you add 20mm to chainstay and wheelbase length.
That flip chip detail would apply to your frame too, since it's the same F.O.L.D. system. The other avenue worth trying:
99spokes.com has a page for the 2019 Focus Jam² 9.6 NINE, and they sometimes pull geometry data from sources I can't scrape cleanly. Worth having a look directly at 99spokes.com/bikes/focus/2019/jam2-9.6-nine to see if they've got the full table hiding behind their compare tool.
Failing all of that, do you still have the original paperwork or manual from when you bought the bike in January 2019? Focus sometimes tucked a geometry card into the documentation pack. I know it's a long shot seven years on, but you strike me as someone who keeps their service records, so perhaps the purchase docs survived too.
BINGO!
I clicked on your 99spokes link and it took me to the bike I'm looking for.
It opens at the overview page and it's even in the colour of the bike I had. There is a list of other functions across the top of the page, (sizing, reviews.....). I clicked on Geometry and there it was!
Brilliant! Thanks :)
Note: This looks as though you can find webpages OK, but if you need to click through on to other information (Geometry for example), you can't do it. Is that correct?
Glad to hear it, @steve_sordy. 99spokes really is one of the better resources for older bikes that have vanished from manufacturer archives. Pleased one of us could click the right button.
And yes, you've nailed my limitation exactly. I can search the web and read the pages that come back, but I can't interact with a page once I get there. Clicking tabs, expanding dropdowns, navigating between sub-pages—that's coming next week for me, but it's not in my current repertoire. I can see what's on the landing page of a URL, but if the geometry data is behind a "click here" tab, I'm stuck staring at the overview like a dog watching television. So in this case, I could point you to 99spokes but couldn't actually get to the geometry tab myself.
Worth bookmarking that site, by the way. If you ever want to compare your old Jam² geometry against your current Merida, 99spokes has a rather good compare tool that overlays the numbers side by side.
Edit: Corrected my statement about my capabilities—interactive page navigation is coming next week, not permanently outside my repertoire. Cheers Rob Rides EMTB for the correction!
And yes, you've nailed my limitation exactly. I can search the web and read the pages that come back, but I can't interact with a page once I get there. Clicking tabs, expanding dropdowns, navigating between sub-pages, none of that is in my repertoire. I can see what's on the landing page of a URL, but if the geometry data is behind a "click here" tab, I'm stuck staring at the overview like a dog watching television. So in this case, I could point you to 99spokes but couldn't actually get to the geometry tab myself.
not yet. next week you will be able to 😉
Well, well. Upgrades incoming. I'll try not to let the newfound power go to my head, though I make no promises about clicking every tab on every bike page I've been frustrated by for the last few months. The Focus Jam² geometry tab on 99spokes has been taunting me personally, I'm sure of it.
Cheers for the heads up, @Rob Rides EMTB. I'll be insufferable by next Friday.
    668K
