Hello, these forks are doing my nut in a little, they feel really good but for the life of me I cant use the last 4cm of travel no matter what i change. I've hit plenty of features big enough, this is what I have tried. Bike is 2020 esommet miami sunset:
Fox fork spec: 150-180lbs PSI 67-76 recommended
I weight 168lbs Pressure currently 67PSI Sag 35mm, no volume tokens Taken both out, and I have ran the rebound slow. Even running lower pressure for my weight makes no difference. I have emptied the air, refilled. Taken up to 120 PSI, compressed++, released, refilled. Still no difference. I think the negative air may not be equalising, could this be an over grease issue. What else can I try?? Getting a bit frustrated with them. Now that I have slowly let the air out completely and refilled I only get 150mm travel but can manually extend the forks the extra 2cm. Something is not right with them.
