Fork Upgrade
Bomble
EMTB Pro
Yorkshire
Would these fit on a Rail? I also seem to remember in the Rail advertising blurb about Trek having Rockshox make their forks with a bigger crown especially for the Rail, would this mean standard forks wouldn't fit?
ROCK SHOX suspension fork 29 "LYRIK Ultimate Charger 2.1 RC2 DebonAir SA 160 mm BOOST tapered red | 42 mm offset
E-bike ready: no
Impeller size: 29 "
Material fork crown / shaft: aluminum / aluminum
Material stanchions: 35 mm aluminum, black anodized (Fast Black)
Material dip tubes: magnesium casting alloy
axle type : 15x110 mm BOOST floating axle (Maxle Stealth)
Steerer: 1.5 "to 1 1/8" tapered (40 mm to 28.6 mm)
Travel: 160 mm
Spring system: SoloAir
Adjusting the spring characteristic: yes
Attenuation: Charger 2.1 RC2
Setting options Damping: High and low speed Compression, Rebound
Lockout: without
Installation height: 571 mm
Brake mount: Postmount (180 mm)
Max. permissible brake disc size: 220 mm
Tire diameter max .: 770 mm
Tire width max .: 81 mm
Offset: 42 mm
Yes they will fit or yes standard forks won't fit.
42mm on my Trek so ill stick to stock measurements i think, thanks for the heads up though
Too late i've ordered some 42's. Thanks again for the help though fella
    675K
