Looking to upgrade the fork on my trusted 2020 Turbo Levo SL Expert Carbon. Im not doing any downhill stuff but rides quite hard from time to time.
Current fork: FOX Performance 34 FLOAT 29, GRIP damper, 51mm offset
Will go for a FOX 36 factory fork with GRIP2, but can't decide which one..
1: is an E-Bike optimized fork essential for such a low weight bike or just overkill? Small bump sensitivity is more important than the big drops...
2: should I go with the OEM 150 mm travel or upgrade to 160 mm? will the climbing performance suffer a lot on the latter option?...
Upgrading the rear shock from the DPS to the DPX2 made a major difference in ride quality, hoping for the same on the front fork..
thanks in advance..
thanks in advance..
