Focus Jam 2 6.7 Charger Dead
Fangs2k
EMTB Pro
Hi folks, I was hoping my second post in the forum wouldn’t be a problem, but seems my Derby Cycle 4500 serial charger has given up the ghost, no lights, just dead. I’ve checked the fuse in the plug, tried a different power cable, but nothing.
I used my bike Friday evening, came back and put it on charge and it was happily charging. Checked it yesterday morning, and the charger lights were off and the bike battery still in the red.
I‘ve got a TEC Pack, at 80% charge currently, and it won’t charge that either.
Obviously, with everything going on at the moment, I’m not expecting a warranty replacement anytime soon, so my question was do any other chargers work with the Focus/E8000 system? I need to find a workaround really, otherwise it’s going to be sitting with a flat battery for who knows how long.
I’ll call the bike shop tomorrow who I believe are still working in some capacity but understandably they’ll be focusing on people who need a bike for work etc.
I‘ve found some RoPD connector chargers on Amazon in Germany for older focus bikes, but nervous if they’ll turn up anytime soon or even work if they do.
Thanks in advance!
Thanks in advance!
hi Tooks
Mine is doing similar today,green light comes on, but then stops charging,will google anything on the web,
Gwyn
Just a silly suggestion . I have had some erratic connections to the bike/charger lead and sometimes giving the magnetic connector a clean with alcohol or methylated spirit and jiggling the connectors together has do ne the trick.
There is a lot on here about the 4500 vs 4000 charger as the former seems to be faulty.
Hope,you get it sorted.......if you are in East Anglia you are welcome to use mine .
Good luck
hi Tooks
Gwyn
Hi Gwyn, I don’t even get a green light, just nothing at all. I can hear it buzzing slightly, so something internal has gone wrong with it I think.
Good luck
Thanks OldBean, I gave the connector a good spray with contact cleaner, and I’ve tried wiggling/jiggling, but still the charger shows no sign of life.
Thanks for the offer of a charge, but unnecessary journeys and all that!
Gwyn, try sticking yours on a warm radiator for 30 mins. The 4500 doesn't like being cold and it works for mine.
Tooks, not any help, but they don't like being left connected for any length of time after they have finished charging. According to Chris Smith on EMBN anyway.
I use a timer on mine for max 3 hrs.....may help
Thanks Peaky, it would appear the charge never actually finished anyway, when I turned the bike on after removing the dead charger it was still saying empty.
Whatever happened to it must have happened shortly after I’d left it happily charging away.
Just an update to this, got a replacement charger delivered from the bike shop today, another 4500 serial unit, and it’s working fine and the bike is recharged now.
Can’t say I have much confidence in the charger going forward, but fingers crossed!
