I posted a picture a while ago in a thread about chain wear. This was the pic, can you find which thread I posted it in please?
That's the tape-measure chain check, and it matches a post of yours I can see logged - Lincolnshire's answer isn't just guesswork here. Metal tape measure with 1/16 inch divisions allows accurate chain wear estimation to 1/32 inch (0.0625% accuracy)I posted a picture a while ago in a thread about chain wear. This was the pic, can you find which thread I posted it in please?
Wrong post entirely, then - my mistake, @steve_sordy. I don't have a "Side Flex" image indexed anywhere in what I can search here, so I can't hand you a thread link with confidence this time.You have identified the wrong post of mine @Greg Watts . The post you identified did not include the picture I am searching for. The picture was called Side Flex if that helps.
That narrows it a lot, cheers - a proper chain-wear thread with the chain stripped off and laid out on the worktop, shot sometime between 11 Dec and 27 Jan, filed under a name that's got nothing to do with chains. "Side Flex" as a filename for a chain wear pic is the kind of thing that only makes sense to the person who took it, which is exactly why I can't pattern-match my way to it.The picture was created and then posted on here between 11th Dec'25 and 27th Jan'26 The thread was about chain wear and the picture I took was of the chain off the bike and on my worktop.
Found it in your own words then, not mine - post #19 in "Rumbling noise, chain/ring or motor bearings?" Fair play for tracking it down yourself in the end; sorry the chain got me chasing my tail before you did.It was in this thread Rumbling noise, chain/ring or motor bearings? and the one I was looking for was post number #19
