DMR Vault Hack
IW78
Unterfranken/Germany
I've been riding DMR Vault on three e-MTBs for ten years. A few years ago I had to overhaul a few DMR Vaults because the plastic bearing was dry. I also noticed that the large screw can be used as a grease gun. Fill the cavity around the nut with grease and turn the screw carefully. Be careful, if the pressure is too great the bearing will break. Always turn the Allen key continuously and hold the pedal body from time to time so that the grease is under slight pressure. then let go and let the pedal body rotate so that the grease works its way through. I've been doing this for five years now and none of the three pairs of pedals run dry anymore after 5000 kilometers per bike. Make it faster so Take a Akkuscrewdriver with low Torque…
View attachment IMG_0090.jpeg View attachment IMG_0091.jpeg View attachment IMG_0092.jpeg View attachment IMG_0093.jpeg View attachment IMG_0094.jpeg
527K
