Discharging Shimano e8000 battery without riding
dirt huffer
312
312
Minneapolis
Is there a way to discharge the battery without riding the bike? I know the easy answer is go ride! But I'm just curious...
Say you were near full power and got mangled up in a crash and can't ride for awhile, and you want to store your battery at a more healthy level
Someone in the Specilized Levo Owners thread discharged theirs by putting it on a work stand, engaging walk mode then holding it down its tape or a rubber band/similar to discharge the battery - assuming you could do this with the Shimano, though I think better option would be to get one of us on here to run it down for you on a ride.
njn
340
178
Is the ideal storage 40% soc and 15°c?
BU-702: How to Store Batteries – Battery University
I've used the bike stand walk mode to fine tune the rear mech, it would likely take hours to drain the battery to an acceptable level, but it would work.
I'd like to see an adapter to connect to a proper RC battery charger with balancing, discharge, storage cycles.
dirt huffer
312
312
Minneapolis
I guess a cable tie and some string is all you need ?
Brilliant - love that Commencal, don't think I have seen one in that colour, looks like some tasty upgrades too?
dirt huffer
312
312
Minneapolis
Just a few things... Deity cz38 handlebar, Origin8 Flux stem with KustomCaps headset top cap, Wolftooth dropper lever, and an e6000 controller remote ?
Doomanic
🛠️Wrecker🛠️
8,478
9,957
I think you'll find the BMS does that already.
Brianjonesphoto
162
120
Seattle USA
My son has an Oset trials bike that I have converted to Lipo batteries. I took 3 H1 automotive bulbs and wired them in series to be a “dummy” load for that 36v 360wh pack. Works great about 5–10 minutes per .1 volt of charge. Cost me nothing as I had the bulbs kicking around the garage loose. A couple 1/4” spade connectors should work to hook the the Shimano battery. I can post photos once I’m home.
Btw nice to see another mango meta. Did you find changing the remotes worth the $$$?
