Cube kathmandu e-bike and quick release a wheel?
peter32
Greece
Hello all!
I am excited to announce to you that I bought recently a new e-bike (Cube Kathmandu EXC 750 2022) :
I have a question refers to the wheels.
Is this e-bike ok to install a wheel quick release on it?
Maybe on the front wheel?
I don't have experience on e-bikes and no technical-knowledge.
If I install a quick release will be easy to remove the wheel and re-install it 100% on my own, with no others help?
I want to notice that the bike is very heavy and has mudguards and disc-brakes.
If its ok and there are products on the market for wheel quick release I would like to suggest me some of them (escpecially high end ones or Cube / Acid ones).
Thanks!
2WheelsNot4
891
689
I think the axle is bolt through, but if it is bolt on(unlikely) then you probably wont be able to swop out the internals, and even if you could if you have no mechanical experience, is that really a job you want to get in to ?.
A bolt through axle is better than a quick release ,it is stronger and safer,and is just as easy to remove. All you need is an allen key.
