Change cassette on Rail 5
Raph-1970
15
Belgium
Hello ;)
I would like to change my cassette on my Rail 5 , my choice would be for an 12v E-Thirteen Helix Race because the first gears are made of steel and easily replaceable .
Is the 9-50 ( 9/11/13/15/17/20/23/27/31/36/42/50 ) cassette compatible with the Bosch CX programming or do I have to change the engine programming ? A bicycle dealer told me that it could put the engine in error if a cassette does not respect the programming of the original cassette SRAM PG-1210 Eagle 11-50 … is this true ?
Raph-1970
15
Belgium
Nobody to answer me ? I ask the question more clearly : I want to replace my original cassette with an E-Thirteen Helix Race because it has the advantage of having 9/11/13/15/17/20/23/27/31/36 steel gears and easily replaceable. I asked a bicycle dealer who told me that pinion 9 could distort the programming of the Bosch motor ... is that true ? And I also replace the original chain with a reinforced KMC , should we modify the chain length or keep the original length ?
Raph-1970
15
Belgium
Nobody to answer me ? I ask the question more clearly : I want to replace my original cassette with an E-Thirteen Helix Race because it has the advantage of having 9/11/13/15/17/20/23/27/31/36 steel gears and easily replaceable. I asked a bicycle dealer who told me that gear 9 could distort the programming of the Bosch motor ... is that true ? And I also replace the original chain with a reinforced KMC , should we modify the chain length or keep the original length ?
RustyMojo
166
105
Gloucestershire
I’d ask the same dealer why it would distort anything…the speed sensor on the rail is attached to the rear disc, the cassette has nothing to do with it as I understand it. I changed to a mullet set up which has a slight disconnect with bike speed, which I think means I lose assistance quicker than before. It can be changed by a Bosch dealer. However this has nothing to do with cassette
Raph-1970
15
Belgium
Thank you so much guys !
The problem is that you can hear anything and everything at bicycle dealers … I also heard that if we do not respect the original tire sizes , it is the same problem 🤔. I will probably install the electric Sram GX and I would like the ideal cassette with the GX , and don't want to make mistakes ; is why your advice is precious to me 😉… if you know from experience another tape than the Helix Race , I am listening .
My rear wheel : Mavic XA Elite Carbon 29” 12x148 Boost ID360 with Michelin E-Wide 29x2.6
RustyMojo
166
105
Gloucestershire
I would personally go for a cassette with the range that’s cheapest to replace. I’m running the standard SX cassette, the range is perfect if not a little more than is needed. Given the ridiculous cost of a replacement 12 speed cassettes I’ll plump for the best value option. Also understanding that the cheapest may not be the best as it may only last half as long
Raph-1970
15
Belgium
it's a good reason to test the Helix cassette, the gears are easily replaceable without changing the complete cassette ...
what do you think ? Or the 12V E-Thirteen TRS cassette (9-10-12-14-16-18-21-24-28-33-39- 46 ) is interesting: the 9/50 is also available .
RustyMojo
166
105
Gloucestershire
My friend ran an e13 cassette for several year so. His manual bike. I would happily run one, but if I remember correctly they are quite expensive. Not sure you’d need the 9t, that’s a very small cog so would wear quickly, but given ebikes are limited assistance to around 16mph (well they are here in the U.K.) pushing a 50lb bike over the assistance limit in that small cog would not be an enviable task.
Also the replacement cog sections look expensive, in fact more than a complete SX cassette…so I’m struggling to see the benefit
Raph-1970
15
Belgium
Ok , thanks for your advice 😉
