Body armour. Again!
But if you are in a narrow rut with the slope on your left going steeply up and the slope on your right going steeply down what is that going to do? Did that once when I stopped on what looked like solid ground to my right but it turned out to be dense foliage so down the slope i went :)
That’s the situation where a tactical dismount can save the day
In that instance I did not need a "tactical dismount". I had simply stopped on the trail and put my foot down as you normally would but I had misjudged the terrain. It looked solid but wasn't but this is getting off the point. I will look into getting some coaching.
Hopefully never but I can assert that it does cover the ribs I have damaged previously and that coverage is rated as Level 1 and it is so comfy I forget I have it on.
Level 1 is comfy, but does not protect much. Go for level 2 if you want to avoid damage if you hit a rock.
    Join 42,861
