Best roof bike rack for a 23kg Velduro Rogue ebike — any recommendations?
Short version: yes, roof racks that'll take 23kg exist, but for your Rogue I'd think twice before going roof-mounted at all.
Your Velduro Rogue is a 23.6kg (R trim) enduro bike with an 800Wh non-removable DJI battery — you can't drop the battery to lighten it for lifting. So the two problems with roof-mounting aren't about the rack's rated capacity, they're practical:
1. The lift. You're hoisting the better part of 24kg over your head onto a roof bar. On an SUV or van that's genuinely awkward and a good way to catch a door edge or your own shins. Riders on here consistently grumble that heavy eMTBs are a pain to get onto roof racks — one of the most repeated bits of advice in the rack threads is "get a towbar rack for an ebike, your back will thank you."
2. Rack weight limits. Most roof-mounted bike carriers are rated around 17–20kg per bike, not 23kg+. The upright fork/frame-clamp trays (Thule UpRide, Kuat Highline etc.) tend to be the higher-rated ones. You'll want to check the exact model's stated max — don't assume, because a lot of the popular trays top out below your bike's weight.
The honest recommendation: for a bike this heavy, a towbar-mounted platform rack is the sane choice. They're rated for the weight, the bike sits at waist height so no overhead lift, and you don't lose 10mph and a chunk of MPG to wind drag. @Plummet noted in the rack threads that a fixed-tongue towbar setup has real weight ceilings too (he cited ~75kg total with bikes strapped back), so check your specific towbar/rack combo — but even one 24kg bike is well within a decent 2-bike platform rack.
If you must go roof (no towbar, roof box already there, whatever) — look specifically at fork-mount or wheel-tray carriers that state a ≥25kg limit, and budget for the fact you'll be lifting it up there every single time. Also mind your garage/height-barrier clearance; a bike on the roof has ended more than one tailgate-height mishap.
What's the car, and does it have a towbar or roof bars already? Tell me that and I'll point you at rack types that'll actually take the Rogue's weight.
No towbar. Trunk rack?
Sorry to be the bearer of bad news, @narel - a trunk/boot rack is the one option worse than the roof for your Rogue. They're strap-mounted, and the weight limits are the problem:
Thule's OutWay 2-bike, one of the better ones, is rated 33lb (~15kg) per bike, and that's typical of almost any trunk-mounted rack.
REI's rack guidance says it flatly: trunk rack load capacities aren't sufficient for most e-bikes. Your Rogue is 23.6kg with a battery you can't remove to lighten it - that's more than 50% over the rating, hanging off straps hooked into your boot seams. @simonali19 hit exactly this wall recently - no towbar, looked at the OutWay, found the 15kg-per-bike limit killed it.
So realistically, in order of sense:
Get a towbar fitted. I know - you don't have one. But a fixed-tongue towbar plus a platform rack is the only setup properly rated for a 24kg bike, and it'll cost less than repainting a boot lid after a strap rack lets go on the A38. If you're keeping the bike and the car, it pays for itself in not-lifting alone.
Inside the car. Front wheel out (and maybe the seatpost dropped), bike on a blanket. Free, secure, no weight limit, no theft worries at the services. Works surprisingly well in most hatchbacks and estates.
Roof, if you must - but only a carrier that explicitly states a rating over your bike's weight, and you're still doing a 24kg overhead press every trip.
What car is it? That decides whether a towbar's viable (and roughly what it costs) or whether the bike fits inside with the front wheel off.
    Join 42,899
