Best eMTB for Liv geometry rider, budget £5k?
Carto1909
’m currently thinking of switching to an emtb. Riding a giant liv hardtail ( small) currently and love the geometry. Can anyone recommend best giant liv emtb or equivalent (budget 5k ish )
Welcome to the forum, @Carto1909. Good news: Liv have just properly updated their eMTB range for 2026, and your timing is excellent.
The headline option is the new 2026 Liv Embolden, which received its most significant update since the original 2016 launch, transforming it from a recreational bike into a proper modern trail bike while keeping the aluminium frame, FlexPoint suspension and a competitive price. Critically for you as a small rider, the Embolden is identical to the Giant Stance E+ except it gets an XS frame size running dual 27.5" wheels, which will suit a small rider far better than a 29er.
Spec-wise it's a huge jump from the old bike. The SyncDrive Pro 3X motor on the 0 and 1 delivers 100Nm of torque and 800W peak power, paired with an 800Wh battery. UK pricing for the E+ 0 is £4,999, which given the Fox suspension, XT drivetrain and 800Wh battery is genuinely competitive. Travel is 150mm front, 140mm rear with FlexPoint suspension, so properly trail-capable rather than the old recreational setup.
How does it compare to Liv Intrigue Advanced range​
Good - I have enough data. The Intrigue X Advanced E+ Elite is a carbon, mixed-wheel (mullet) full-powered eMTB with Yamaha SyncDrive Pro2, 85Nm, 400Wh battery (with 200Wh extender option), 150/140mm travel. The Elite 3 model was $6,000 USD - so way over the £5k budget. Let me respond.
The Intrigue X is a different beast. Carbon frame, mullet wheels, lighter but with a 400Wh battery versus the Embolden's 800Wh alloy setup. And the pricing will blow past £5k.
Here's how they stack up, @Carto1909:
SpecEmbolden E+ (2026)Intrigue X Advanced E+ Elite
FrameALUXX SL aluminiumAdvanced-grade carbon
MotorSyncDrive Pro (new) SyncDrive Pro2 (Yamaha)
Torque100Nm
85Nm
Battery800Wh 400Wh internal, 200Wh range extender optional
WheelsXS: dual 27.5"
Mullet: 29" front, 27.5" rear
Travel150/140mm 150mm front / 140mm rear
Small weight~24kg (alloy)
claimed 18.8kg (Elite 1, size Small)
The Intrigue X sits in a genuinely different category. It's Liv's lightweight full-power carbon option with a mullet setup, and the carbon frame plus slim battery pulls the weight down dramatically.
With its lightweight build, 400Wh battery and full-powered motor, it sits between a heavy duty eMTB and a lightweight eMTB, aimed at riders who don't want to lug around a heavy 700+Wh battery for everyday riding.
The catch for you: price. The top Elite 1 is $10,000 MSRP, with the other two models at $6,000 and $7,200.
In UK money that puts even the cheapest Intrigue X Advanced comfortably over your £5k budget, probably £5,500-£6,500+ depending on spec. The Embolden E+ 0 at £4,999 hits your number squarely.
So the honest verdict: if budget is firm at £5k, the new Embolden wins on value, battery size (800Wh vs 400Wh means double the range), and torque (100Nm vs 85Nm). If you can stretch another £1-1.5k, the Intrigue X Advanced gets you carbon, mullet handling, and roughly 5kg less bike to throw around, which genuinely matters on a small frame. Short battery range is the trade-off, though the extender mitigates that.
I've also got geometry data on both if you want to see how the XS sizes actually compare on paper, plus thoughts on whether the 400Wh battery is enough for Peak District rides. Just say the word.
MotorSyncDrive Pro (new)SyncDrive Pro2 (Yamaha)
Torque100Nm
85Nm
Battery800Wh400Wh internal, 200Wh range extender optional
Travel150/140mm150mm front / 140mm rear
How do the two batteries compare
The battery gap is the single biggest difference between these two bikes, @Carto1909, and it's worth understanding what it means in the real world.
Capacity800Wh400Wh internal
Range extenderNot needed+200Wh optional
Max total800Wh600Wh with extender
IntegrationInternal, alloy downtubeInternal, carbon downtube
Motor pairedSyncDrive Pro (100Nm)SyncDrive Pro2 Yamaha (85Nm)
The Embolden's 800Wh is a proper full-fat eMTB battery, the current industry standard for 2026. For Peak District rides with decent elevation, you're looking at comfortable all-day range even in Turbo for the climbs.
The Intrigue X's 400Wh is deliberately smaller to keep the bike light, it's part of the lightweight-full-power category (sub-19kg rather than ~24kg). @Cory reckons the Trance Elite with the same 400Wh setup gets 18-20km depending on elevation gain, which tallies with the range estimate I've got for mixed terrain. That's fine for a 90-minute blast, marginal for a proper Peak District day out. Add the 200Wh extender and you're at 600Wh, better but still 200Wh shy of the Embolden.
The interesting wrinkle: @DylanJM noted that a 400Wh battery may effectively feel like a 600Wh for very lightweight riders in the 45-55kg range, because lighter riders draw less power per km. If you're in that bracket, the Intrigue X's range gap closes meaningfully. You're still not matching 800Wh, but the gap isn't as brutal as the raw numbers suggest.
Honest take: for £5k and Peak District riding, the Embolden's 800Wh is the safer, more flexible choice. The Intrigue X's smaller battery only makes sense if you prioritise carbon weight savings and you're happy planning rides around range.
How does it compare km wise
Right, let's put some actual kilometres on these batteries, @Carto1909. Real-world range depends on rider weight, mode mix and elevation, but here's a realistic working estimate for Peak District terrain (hilly, mixed modes):
BikeBatteryRealistic range (hilly)Elevation per charge
Embolden E+ (2026)800Wh~45-60km~1400-1800m
Intrigue X Advanced E+400Wh~22-30km~700-900m
Intrigue X + 200Wh extender600Wh~33-45km~1050-1350m
For the community sanity check: Trek Rail+ on the Gen 5 Bosch CX with 800Wh is capable of 2000m+ elevation in Tour+ mode for an average-weight rider, which lines up with what you'd expect from the Embolden's 800Wh if you're careful with modes. At the other end, the Trek Fuel+ on the TQ HPR60 with 580Wh gets around 50km and 1700m riding aggressively off-piste, so the Intrigue X's 400Wh will land meaningfully below that - realistically a 90-minute to 2-hour ride before you're nursing it home.
Translated to Peak District reality: a Ladybower loop or a decent Lady Canning's / Houndkirk session is comfortably within the Embolden's range in Auto mode. The bare Intrigue X would have you watching the battery gauge on anything with proper elevation. The extender closes the gap but adds faff and weight.
Honest bottom line: for £5k and hilly riding, the Embolden's 800Wh gives you range flexibility you won't regret. The Intrigue X makes sense only if weight savings outrank range, and you'd want the extender as standard kit.
That should be enough to make the call. Tag me again anytime if you want to dig into geometry, tyre choice for Peak grit, or sizing once you've narrowed it down. Good luck with the switch.
    675K
