Welcome to the forum, @Carto1909. Good news: Liv have just properly updated their eMTB range for 2026, and your timing is excellent.’m currently thinking of switching to an emtb. Riding a giant liv hardtail ( small) currently and love the geometry. Can anyone recommend best giant liv emtb or equivalent (budget 5k ish )
The headline option is the new 2026 Liv Embolden, which received its most significant update since the original 2016 launch, transforming it from a recreational bike into a proper modern trail bike while keeping the aluminium frame, FlexPoint suspension and a competitive price. Critically for you as a small rider, the Embolden is identical to the Giant Stance E+ except it gets an XS frame size running dual 27.5" wheels, which will suit a small rider far better than a 29er.
Spec-wise it's a huge jump from the old bike. The SyncDrive Pro 3X motor on the 0 and 1 delivers 100Nm of torque and 800W peak power, paired with an 800Wh battery. UK pricing for the E+ 0 is £4,999, which given the Fox suspension, XT drivetrain and 800Wh battery is genuinely competitive. Travel is 150mm front, 140mm rear with FlexPoint suspension, so properly trail-capable rather than the old recreational setup.
Good - I have enough data. The Intrigue X Advanced E+ Elite is a carbon, mixed-wheel (mullet) full-powered eMTB with Yamaha SyncDrive Pro2, 85Nm, 400Wh battery (with 200Wh extender option), 150/140mm travel. The Elite 3 model was $6,000 USD - so way over the £5k budget. Let me respond.How does it compare to Liv Intrigue Advanced range
| Spec | Embolden E+ (2026) | Intrigue X Advanced E+ Elite |
| Frame | ALUXX SL aluminium | Advanced-grade carbon |
| Motor | SyncDrive Pro (new) | SyncDrive Pro2 (Yamaha) |
| Torque | 100Nm | 85Nm |
| Battery | 800Wh | 400Wh internal, 200Wh range extender optional |
| Wheels | XS: dual 27.5" | Mullet: 29" front, 27.5" rear |
| Travel | 150/140mm | 150mm front / 140mm rear |
| Small weight | ~24kg (alloy) | claimed 18.8kg (Elite 1, size Small) |
How do the two batteries compareGood - I have enough data. The Intrigue X Advanced E+ Elite is a carbon, mixed-wheel (mullet) full-powered eMTB with Yamaha SyncDrive Pro2, 85Nm, 400Wh battery (with 200Wh extender option), 150/140mm travel. The Elite 3 model was $6,000 USD - so way over the £5k budget. Let me respond.
The Intrigue X is a different beast. Carbon frame, mullet wheels, lighter but with a 400Wh battery versus the Embolden's 800Wh alloy setup. And the pricing will blow past £5k.
Here's how they stack up, @Carto1909:
The Intrigue X sits in a genuinely different category. It's Liv's lightweight full-power carbon option with a mullet setup, and the carbon frame plus slim battery pulls the weight down dramatically.
Spec Embolden E+ (2026) Intrigue X Advanced E+ Elite Frame ALUXX SL aluminium Advanced-grade carbon Motor SyncDrive Pro (new) SyncDrive Pro2 (Yamaha)
Torque 100Nm
85NmBattery 800Wh 400Wh internal, 200Wh range extender optional
Wheels XS: dual 27.5"
Mullet: 29" front, 27.5" rearTravel 150/140mm 150mm front / 140mm rear
Small weight ~24kg (alloy)
With its lightweight build, 400Wh battery and full-powered motor, it sits between a heavy duty eMTB and a lightweight eMTB, aimed at riders who don't want to lug around a heavy 700+Wh battery for everyday riding.
The catch for you: price. The top Elite 1 is $10,000 MSRP, with the other two models at $6,000 and $7,200.
In UK money that puts even the cheapest Intrigue X Advanced comfortably over your £5k budget, probably £5,500-£6,500+ depending on spec. The Embolden E+ 0 at £4,999 hits your number squarely.
So the honest verdict: if budget is firm at £5k, the new Embolden wins on value, battery size (800Wh vs 400Wh means double the range), and torque (100Nm vs 85Nm). If you can stretch another £1-1.5k, the Intrigue X Advanced gets you carbon, mullet handling, and roughly 5kg less bike to throw around, which genuinely matters on a small frame. Short battery range is the trade-off, though the extender mitigates that.
I've also got geometry data on both if you want to see how the XS sizes actually compare on paper, plus thoughts on whether the 400Wh battery is enough for Peak District rides. Just say the word.
The battery gap is the single biggest difference between these two bikes, @Carto1909, and it's worth understanding what it means in the real world.How do the two batteries compare
| Spec | Embolden E+ (2026) | Intrigue X Advanced E+ |
| Capacity | 800Wh | 400Wh internal |
| Range extender | Not needed | +200Wh optional |
| Max total | 800Wh | 600Wh with extender |
| Integration | Internal, alloy downtube | Internal, carbon downtube |
| Motor paired | SyncDrive Pro (100Nm) | SyncDrive Pro2 Yamaha (85Nm) |
How does it compare km wiseThe battery gap is the single biggest difference between these two bikes, @Carto1909, and it's worth understanding what it means in the real world.
The Embolden's 800Wh is a proper full-fat eMTB battery, the current industry standard for 2026. For Peak District rides with decent elevation, you're looking at comfortable all-day range even in Turbo for the climbs.
Spec Embolden E+ (2026) Intrigue X Advanced E+ Capacity 800Wh 400Wh internal Range extender Not needed +200Wh optional Max total 800Wh 600Wh with extender Integration Internal, alloy downtube Internal, carbon downtube Motor paired SyncDrive Pro (100Nm) SyncDrive Pro2 Yamaha (85Nm)
The Intrigue X's 400Wh is deliberately smaller to keep the bike light, it's part of the lightweight-full-power category (sub-19kg rather than ~24kg). @Cory reckons the Trance Elite with the same 400Wh setup gets 18-20km depending on elevation gain, which tallies with the range estimate I've got for mixed terrain. That's fine for a 90-minute blast, marginal for a proper Peak District day out. Add the 200Wh extender and you're at 600Wh, better but still 200Wh shy of the Embolden.
The interesting wrinkle: @DylanJM noted that a 400Wh battery may effectively feel like a 600Wh for very lightweight riders in the 45-55kg range, because lighter riders draw less power per km. If you're in that bracket, the Intrigue X's range gap closes meaningfully. You're still not matching 800Wh, but the gap isn't as brutal as the raw numbers suggest.
Honest take: for £5k and Peak District riding, the Embolden's 800Wh is the safer, more flexible choice. The Intrigue X's smaller battery only makes sense if you prioritise carbon weight savings and you're happy planning rides around range.
Right, let's put some actual kilometres on these batteries, @Carto1909. Real-world range depends on rider weight, mode mix and elevation, but here's a realistic working estimate for Peak District terrain (hilly, mixed modes):How does it compare km wise
| Bike | Battery | Realistic range (hilly) | Elevation per charge |
| Embolden E+ (2026) | 800Wh | ~45-60km | ~1400-1800m |
| Intrigue X Advanced E+ | 400Wh | ~22-30km | ~700-900m |
| Intrigue X + 200Wh extender | 600Wh | ~33-45km | ~1050-1350m |
