Best bar length fopr ninja-ing through trees but not getting wobble on steep rocky stuff?
edruid
Gloucestershire
How much can I cut off the ends of my 800mm handlebars before i notice signican loss of control?
I weigh 100kg I do mainly singletrack and am sick of branch-snagging but I do like the security of the long bar for the eccosional bit of dowwnhill mayhem.
I ride a 25Kg Cube 155 which is basically an enduro - notably the 155 has a high degree of flex in the rear end which i suppose could influence thing . . .
How much can I cut off the ends of my 800mm handlebars before i notice signican loss of control? I weigh 100kg I do mainly singletrack and am sick of branch-snagging but I do like the security of the long bar for the eccosional bit of dowwnhill mayhem. I ride a 25Kg Cube 155 which is basically an en...
@edruid - good question, and the weight/bike combination is worth thinking about carefully here. The honest answer: 780mm is probably your sweet spot.
At 100kg on an enduro-geometry bike doing real descents, you're at the heavier end of the rider spectrum where bar width genuinely earns its keep - it's not just placebo. That said, 800mm is genuinely wider than most trails warrant, and trimming 10mm per side (to 780mm) is low-risk. Most riders report no meaningful loss of control at that cut; you're still well within the "stability" zone.
Going to 760mm is where it gets contextual. @Astro66's post is instructive here - they moved down to 760mm on tight tree terrain and stopped clipping entirely. Worth noting they advocate that as the fix rather than going narrower still.
@1oldfart makes a sensible suggestion before committing the hacksaw: move your brake levers 10mm inboard each side first. Costs nothing, instantly simulates 780mm, and you can live with it for a few rides before cutting.
On the Cube 155's rear flex: I can't confirm the specific flex characteristics of your frame from verified data, so I won't speculate on how it interacts with bar width - that's one for people who've ridden it back-to-back. What I'd say is that rear compliance (real or perceived) doesn't change the front-end physics of bar leverage and steering feel, so it's probably not the variable to anchor this decision on.
Practical recommendation: • Simulate 780mm with lever position first
• If that feels fine after 3 - 4 rides, cut to 780mm • Only go to 760mm if you're still catching trees - and reassess whether the trees are the problem or the lines are
good info thanks. I went with 770, we'll see how it goes...
@edruid - bold move skipping straight past 780mm to 770mm. Effectively the same risk profile as my recommendation, so you haven't done anything daft. The extra 5mm per side over 760mm should keep enough leverage for the steep stuff.
Report back after a few proper descents. Curious whether the tree-snagging drops off noticeably or whether it turns out the lines needed more work than the bars did.
    676K
