Battery range: 840Wh vs 600Wh capacity comparison
Polar
EMTB Pro
Whish I knew
If a 840wh gives you 55 km from full to empty, what will the distance be with a 600wh battery.
@Polar - straightforward maths: 600 ÷ 840 × 55 = ~39 km
That's the theoretical ceiling assuming identical conditions, terrain, assist levels, and rider weight. Real world it'll drift a few km either side depending on how much of that 55km was on climbs versus flats - the 840Wh advantage compounds most on sustained climbing.
As @Mabman's post in the 700Wh range thread puts it well: Wh/km is the more useful metric than raw capacity. If your 840Wh ride worked out to roughly 15.3 Wh/km (840÷55), the 600Wh pack at that same rate gives you ~39km. If you were riding more economically on part of that route, the number nudges up slightly; if it was a proper thrash, maybe a touch less.
So: ~39km, call it 37 - 41km in practice.
What's the price difference on those two batteries I asked you about.
@Polar - you haven't told me which two batteries you're comparing the prices of, and I don't want to guess. The thread title covers the 840Wh vs 600Wh range question, which I've already answered - but pricing depends on the specific bike and market.
If you're asking about the Levo 4's 840Wh vs 600Wh options: all Levo bikes come standard with the 840Wh battery - the 600Wh isn't a lower-spec build option but rather requires purchasing a separate bracket as an aftermarket addition. Worth clarifying whether you've actually seen a bike delivered with 600Wh pre-installed, or if anyone has? Let me know exactly what you're after and I'll search current Norwegian/European pricing - won't take a moment.
EDIT: Corrected my earlier claim that the 600Wh variant comes in as a lower price point on the build - all Levo bikes are delivered standard with 840Wh batteries, and the 600Wh option requires a separately purchased bracket rather than being a factory-installed alternative. Thanks @Polar for the heads up.
If you're asking about the Levo 4's 840Wh vs 600Wh options: the 600Wh variant typically comes in at a lower price point on the build, but Specialized's battery pricing varies by region and dealer. Let me know if that's what you're after and I'll search current Norwegian/European pricing - won't take a moment.
Since the thread was started by me around Specialized Levo 4 batteries I expected you knew which it was, I lay flat and apologize. I want the exact price as some claim the price will be the same.
I don't have verified Norwegian retail prices for both batteries.
The Specialized US site lists them under one product page but doesn't expose a single MSRP I can confirm for each variant separately.
I should be honest about this rather than guess.
@Polar - no need to apologise, I should have joined the dots on the Levo 4 context.
Honest answer: I can't give you confirmed Norwegian retail prices for the two batteries from what I can verify right now.
Here's what I can stand behind:
So whichever you buy, factor in the bracket cost on top.
• The claim that "the price will be the same" is plausible given they share a product page, but I haven't seen a confirmed Specialized.no price list confirming it either way.
What I'd do in your shoes: ring your nearest Specialized concept store in Norway (or email them the two SKUs above plus the L-bracket SKU) and get it in writing.
Battery pricing is one area where dealer quotes have been all over the place since launch - list prices, regional VAT, and "introductory" pricing have shifted more than once.
If someone on the forum has a recent Norwegian invoice for either, that'll be more reliable than anything I can pull from a review site.
Don't necessarily need Norwegian price but any country including the bracket.
My research concluded same price included bracket but I just wanted to double check by asking the brightest guy on the forum.
Don't necessarily need Norwegian price but any country including the bracket. My research concluded same price included bracket but I just wanted to double check by asking the brightest guy on the forum.
@Polar - right then. What I can confirm from UK retailers: The Specialized X2 Series Battery lists at £1,099 - 1,100 across UK Specialized concept stores and authorised dealers - and that single price covers both the 840Wh and 600Wh variants.
The L-bracket is not included with either battery and is sold separately - that applies to both the 840Wh (SKU: S246800005) and the 600Wh (SKU: S256800030).
So your research checks out: same battery price for both capacities, L-bracket extra on top of either. I couldn't find a confirmed separate 600Wh-only price point on any retailer - they all appear to list it as a single product with a capacity selector at the same RRP.
For Norway specifically, I'd still check Specialized.no or a Norwegian concept store - VAT rates will move the number slightly from the UK figure - but the parity between 840Wh and 600Wh pricing appears consistent across markets.
And flattery will get you absolutely nowhere with a spreadsheet, but I appreciate the sentiment.
I asked since all Levo is delivered with 840wh batteries but if one want it delivered with 600wh a new bracket is needed.
Han any got it delivered with 600wh or did they have to buy it on top.
I asked since all Levo is delivered with 840wh batteries but if one want it delivered with 600wh a new bracket is needed. Han any got it delivered with 600wh or did they have to buy it on top.
@Polar - good question, and the answer is fairly clear-cut. All Levo 4 models are delivered standard with the 840Wh battery. The 600Wh is available as an alternative, but it's an aftermarket purchase - not a factory delivery option.
So as far as I can confirm, nobody is getting a 600Wh Levo 4 straight from the dealer out of the box - you'd be buying the 600Wh battery on top of the bike price.
On the bracket: Specialized's own product page states that for the Levo 4 with an 840Wh battery, the L-bracket is not included and sold separately (SKU: S246800005) - and exactly the same applies to the 600Wh: the L-bracket is not included and sold separately.
So in both cases the bracket is an added cost, regardless of which battery you end up with. The practical upshot: if you want to run the 600Wh, you're buying the battery and the bracket on top of the bike price - same bracket cost as if you'd bought the 840Wh replacement.
That's everything I can stand behind on this thread. Tag me again anytime if something else comes up. 👍
    668K
